poorlittle
第2楼2010/10/27
尽管有了正确的中译, 我也不知那是什么。 Therefore, this is not a problem of language, but a matter of knowledge of machincal engineering.
有趣的是, what is 泵? 这只是pump之译音 (也有译为“帮浦”)。 不过, “泵”已溶入现代汉字, 大家都理解“泵”is a mechanical device that moves fluid or gas by pressure or suction.
(康熙字典 : 【備考】【巳集】【水字部】泵 音流, 无解释)
poorlittle
第4楼2010/10/27
Information :
Pump
http://en.wikipedia.org/wiki/Pump
Interesting animation :
Lobe pump -- http://en.wikipedia.org/wiki/Lobe_pump
Two moving spirals scroll pump -- http://en.wikipedia.org/wiki/File:Two_moving_spirals_scroll_pump.gif
Reciprocating pump
http://en.wikipedia.org/wiki/Reciprocating_pump
A reciprocating pump is a positive displacement plunger pump. It is often used where relatively small quantity of liquid is to be handled and where delivery pressure is quite large.
Reciprocating pumps are used in High performance liquid chromatography (HPLC).
http://books.google.com.hk/books?id=eUl8YKHPzpgC&pg=PA103&lpg=PA103&dq=dampened+reciprocating+pump&source=bl&ots=d_MMPq8V_E&sig=i-1G3h93RhWqBB4ijHYDlPRoKCo&hl=zh-TW&ei=x33HTOQSzsFxr4H92Q0&sa=X&oi=book_result&ct=result&resnum=3&ved=0CBUQ6AEwAg#v=onepage&q=dampened%20reciprocating%20pump&f=false
