Jana 建立了一套分析细胞培养的流感病毒A疫苗产品中糖蛋白的N-多糖类型的方法[6]。该方法主要的检测手段就是对N-多糖酶切后的寡糖进行APTS荧光标记,然后利用毛细管凝胶电泳进行分离检测。APTS标记的例子还有很多,比如Marie-Eve用APTS标记的方法,分析了聚合度在2-6的甲壳素与壳聚糖的混合物[7]。对于APTS在衍生化过程中所出现的很多不可预知的结果,Bui等人做了系统的研究[8],分别比较了不同类型的单糖及低聚糖与APTS反应后的峰面积大小,研究发现不同类型的糖与APTS的反应活性不同,其中氨基糖的反应活性最弱。该篇文献对于APTS的正确应用提供了非常好的指导。
[1] Peter Mikuˇs, Iva Val´aˇskov´a, Emil Havr´anek. Analytical characterization of hepa rin by capillary zone electrophoresis with conductivity detection and polymeric buffer additives. [J] Journal of Pharmaceutical and Biomedical Analysis 36 (2004) 441–446
[2] Jos´e Manuel Herrero-Mart´ıneza,b, Peter J. Schoenmakersa, Wim Th. Koka,. Determination of the amylose–amylopectin ratio of starches by iodine-affinity capillary electrophoresis. [J] Journal of Chromatography A, 1053 (2004) 227–234
[3] Anikó Kilár;Béla Kocsis;Ildikó Kustos;etc. CE to monitor endotoxins by protein Complexation [J] Electrophoresis 2006, 27, 4188–4195
[4] Nicola Volpi Application of high-performance capillary electrophoresis to the purification process of Escherichia coli K4 polysaccharide [J] Journal of Chromatography B, 811 (2004) 253–256
[5] Nicola Volpi Purification of the Escherichia coli K5 capsular polysaccharide and use of high-performance capillary electrophoresis to qualitative and quantitative monitor the process [J] Electrophoresis 2004, 25, 3307–3312
[6] Jana Schwarzer ;Erdmann Rapp;Udo Reichl . N-glycan analysis by CGE–LIF: Profiling influenza A virus hemagglutinin N-glycosylation during vaccine production [J] Electrophoresis 2008, 29, 4203–4214
[7] Marie-Eve Beaudoin, Julie Gauthier, Isabelle Boucher, etc. Capillary electrophoresis separation of a mixture of chitin and chitosan oligosaccharides derivatized using a modified fluorophore conjugation procedure [J] J. Sep. Sci. 2005, 28, 1390–1398
[8] Annamária Bui , Béla Kocsis , Ferenc Kilár . Methodology to label mixed carbohydrate components by APTS
[J] J. Biochem. Biophys. Methods 70 (2008) 1313–1316
[9] Li Qi, Shu-Feng Zhang, Min Zuo, Yi Chen. Capillary electrophoretic determination of glucosamine in osteoarthritis tablets via microwave-accelerated dansylation [J] Journal of Pharmaceutical and Biomedical Analysis 41 (2006) 1620–1624
[10] Guangming Huang, Yi Lv, Sichun Zhang, Chengdui Yang, etc. Development of an Aerosol Chemiluminescent Detector Coupled to Capillary Electrophoresis for Saccharide Analysis [J] Anal. Chem. 2005, 77, 7356-7365
