影子
第2楼2010/12/20
下面的内容也许有助于对这句话的理解:
Counting, Computing and Reporting Results
Optimal colony density per filter is 20 to 200. Report all colonies counted as colony forming-units
(CFU)/mL. Include in the report the method used, the incubation temperature and time, and
the medium.
For example: 98 CFU/L, mL, 35 °C, 24 hours, m-HPC broth.
1 to 2, or fewer colonies per square — Count all of the colonies on the filter, and divide the
results by the volume of original sample used.
For example, if there are 122 colonies on the filter, and the volume of original sample used was 10
mL, compute results as follows:
122 colonies
---------------------- = 12.2 CFU/mL
10 mL sample
3 to 10 colonies per square — Count all colonies in 10 representative squares and divide by 10
to obtain an average number of colonies per square. Multiply this number by 100 and divide by the
For example, if you calculated an average of 8 colonies per square, and the volume of original
sample used was 0.1 mL, compute results as follows:
8 colonies/square x 100
------------------------------------ = 8000 CFU/mL
0.1 mL sample
10 to 20 colonies per square — Count all colonies in 5 representative squares and divide by 5 to
For example: if there are an average of 17 colonies per square, and the volume of original sample
17 colonies/square x 100
------------------------------------- = 17, 000 CFU/mL
0.1 mL sample
原文如下:
poorlittle
第3楼2010/12/20
From p. 23 of “MICROBIOLOGICAL EXAMINATION” (http://www.env.gov.bc.ca/epd/wamr/labsys/lab-man-09/pdf/section-e-2009.pdf )
g) Count colonies on membrane filters at 10 to 15 x magnification.
Preferably place petri dish on microscope stage slanted at a 45° angle
and adjust the light source vertical to the colonies. Optimal colony
density per filter is 20 to 200. If colonies are small and there is no
crowding, a higher limit is acceptable. Count all colonies on the
membrane when there are 1 to 2, or fewer, colonies per square. For 3
to 10 colonies per square count 5 squares and obtain average count
per square. Multiply average count per square by 100 times the
reciprocal of the dilution to give colonies per millilitre. If there are more
than 20 colonies per square, record count as >2000 times the
reciprocal of the dilution. Record counts only when there are discrete
separate colonies without spreaders.
I am 外行 too.
Square : 方格?
影子
第5楼2010/12/20
在这里square应该就是指“方格”,看下面的图示:
从上面我附的这篇文章来看,菌落数的计算方式有以下三种:
1 to 2, or fewer colonies per square —Count all of the colonies on the filter, and divide the
如果一个方格上的菌落数为1-2个或者更低,则直接将滤膜上所有菌落数的总和除以取样体积即得测试结果(单位是CFU/ml)。
3 to 10 colonies per square —Count all colonies in 10 representative squares and divide by 10 to obtain an average number of colonies per square. Multiply this number by 100 and divide by the volume of original sample used.
如果一个方格上的菌落数为3-10个,则取10个有代表性的方格进行计算。
10 to 20 colonies per square —Count all colonies in 5 representative squares and divide by 5 to obtain an average number of colonies per square. Multiply this number by 100 and divide by the volume of original sample used.
如果一个方格上的菌落数为10-20个,则取5个有代表性的方格进行计算。
