1.Another common type of resistor is the thin-film resistor.This is made by depositing a thin film of metal on a cylindrical insulating support.High resistance values are a consequence of the thinness of the film.
2.Resistors are circuit element having specified values of resistance support;and these wire-wound resistors are generally used when it may be necessary to dissipate considerable heat.
