第1楼2002/07/18
leeman是主要的ICPAES生产商之一。虽然原理上是扫描型的仪器,但profile系统采用专利的技术是检测器移动而非波长扫描。具体信息请与其北京办事处联系:68317070,68344195。
Leeman Labs, Inc. has manufactured Inductively Coupled Plasma Optical Emission Spectrometers (ICP-OES) since 1981. Our ICP spectrometers are designed to deliver the performance that analysts demand, day in and day out. The Profile Plus ICP comes in axial, radial and dual view configurations; choose the configuration best suited to your analytical requirements.
Features that make a difference:
High Resolution
Minimizes spectral interferences for superior accuracy and improved analytical performance
Eliminates the need for almost all troublesome inter-element corrections
Full wavelength coverage (170-780nm)
Fully Automated
All operating parameters are computer controlled including sample handling with built-in autosampler
On-peak Measurements
Fast, accurate measurements
Analysis does not require peak searching which is prone to selecting incorrect wavelengths
Compact Benchtop ICP
Lab space is expensive. The Profile Plus ICP is self-contained and fits comfortably on a standard lab bench
Axial, Radial or Dual View Optics
Axial view can improve detection limits by 5-20x
Radial view can handle tougher matrices
Dual view allows line-by-line selection of viewing configuration
Auto-Align Torch
Eliminates variability in torch installation and alignment
Rugged RF Generator
The water-cooled 40.68 MHz free-running RF generator is long lived and provides
superior tolerance to a wide variety of sample types including high solids and volatile organics
WinICP Software
Easy-to-use, designed for Windows® 95, 98, 2000, ME and NT.
Qualitative, fast semi-quantitative, and quantitative analysis
On-line help
Built-in maintenance scheduler
