The median number is used to perform an average filtering on the reading. The median is performed before the moving average.
For example, a median filter of 10 readings is the median of previous 10 readings.
If readings are RM, RM-1,…,RM-9, the formula is:
Result = median[RM, RM-1,…,RM-9]
The range of this value is between 0 and 10.
中间数用来在读数上去执行一个平均值的过滤。浮动平均前中间值会被执行。
例如:一个中间值的读数是10是以前10数的中值。
如果读数是RM, RM-1,…,RM-9,公式是:
这个值的范围是在0~10之间。
这一句最费解!
