It has been sunny these days, and the temperature goes up to a relatively high level. I smell the taste of summer!
However, I work in the lab, where the temperature stays at a steady value about 20 degree centigrade. I can feel the difference between inside and outside of the lab obviously!
Although the temperature is near 20 degree centigrade, the mode of the air-conditioner is refrigeration mode, which means people will feel cold staying in the room for hours! So, we have to wear clothes with long sleeves in the room!
Morning, here is also cold. I have to wear a sweater and a thicker jacket to keep warm. When I ride bicycle, the gloves should be necessary. The better news: my waist seemed better now.
The air-conditioner system is swtiched off in my company recently. The temperature is not distinctive between inside and outside. But the temperature difference between inside and outside is obvious in winter and summer.
天黑请闭眼(shxie)发表:Morning, here is also cold. I have to wear a sweater and a thicker jacket to keep warm. When I ride bicycle, the gloves should be necessary. The better news: my waist seemed better now.
