poplar_yang
第5楼2011/01/08
usually if you setup in program 30KV, that means the sample inlet of capillary is negative -30KV, the signal outlet point is positive.
I don't have your machine, so I don't know, if you setup in your program -30KV, that will probably be: the sample inlet of capillary is positive +30KV, the signal outlet point is negative.
