第1楼2005/12/25
What is Chemistry ?
Chemistry is frequently defined as the study of matter and the reactions that matter undergoes. Actually, physicists, geologists, and biologists also study matter, but only chemists study the reactions that matter undergoes. For example, only chemists make compounds and try to understand the reactions that produce the compounds. Indeed, a very large segment of chemists are employed by the chemical and pharmaceutical industry for the very purpose of preparing new plastics, coatings, ceramics, drugs, fillers, alloys, and so on. These synthetic chemists must first determine what reaction can be used to synthesize their target compound and then determine what conditions will optimize the yield of the compound in order to make the compound in the most cost-effective way. After the best reaction conditions have been determined, the chemist must determine how to purify the compound, and, finally, the chemist must identify it. This final process of identification usually includes not only being certain that the compound contains the right percentage of the various elements from which it is composed, but also involves the determination of the 3-dimensional structure of the compound.
Structural details are often crucial to the activity of the compound. For example, the compounds dextrophane and levorphane differ in a very subtle way. They are non-superimposable mirror images of one another in the same way that our hands are non-superimposable mirror images of one another. Yet, because of a quirk of the evolutionary process, our bodies are able to recognize this subtle difference and produce a very different response to the two compounds: levorphan is more strongly analgesic and addictive than morphine, whereas dextrophan is neither addictive nor an analgesic. Figure 1 shows the structural formulas of the two compounds (we will discuss the various types of formulas in a later section). In Figure 2, the same molecules are shown as computer generated molecular models. In part (a), ball and stick models are shown, while part (b) shows space-filling models.
