zlignc
第1楼2011/02/25
If you load a large sample volume onto your SPE cartridge or disk, your analyte may come out when you load your sample. The load volume when your analyte just start to come out can be called 穿透体积. You can continously load your sample, collect and monitor the eluent for the analyte concentration to determine 穿透体积.
