阿迈
第3楼2011/03/17
“Ignite to constant weight” means that ignition shall be continued at 800 ± 25ºC, unless otherwise indicated, until two consecutive weighings, the second of which is taken after an additional period appropriate to the nature and quantity of the residue, do not differ by more than 0.50 mg per g of substance taken.
“灼烧至恒定重量”意为灼烧将被维持在800 ± 25ºC,除非另有陈述,直到两次连续的称重中,残留物的性质和总量在恰当的附加周期后的第二次称量,称取的物质中每克不应超出0.5毫克。
不好意思,今天来晚了,白天有事外出了。
