poorlittle
第2楼2015/05/04
Blank and Control Check maybe two similar but different things.
From http://www.epa.gov/fem/pdfs/Env_Measurement_Glossary_Final_Jan_2010.pdf
Blank
A specimen that is intended to contain none of the analytes of interest and which is subjected tothe usual analytical or measurement process to establish a zero baseline or
background value. Different types of blanks include:
Calibration Blank
Equipment Blank
Field Blank
Control Check
A check using QualityControl Check Sample where Quality Control Check Sample (QCS) is :
A sample containing all or a subset of the analytes atknown concentrations. The QCS is obtained from a source external to
the laboratory or is prepared from a source ofstandards different from the source of calibration standards. It is used tocheck laboratory performance with test materials prepared external to thenormal preparation process………….
钻石的眼泪
第3楼2015/05/06
朋友回答的好专业啊
