本人急需以下几个标准: ASTM F 1281 交联聚乙烯/铝/交联聚乙烯(PEX-AL-PEX)压力管 ASTM F 1335 高温设备用标定压力复合管道及其配件
ISo 15877, ISO 15877-1:en. Plastics piping systems for hot and cold water installations. Chlorinated poly(vinyl chloride) (PVC-C). Part 1: General (ISO 15877-1:2003). ISO 15877-3:2003 specifies the characteristics of fittings for chlorinated poly(vinyl chloride) (PVC-C) piping systems ISO 15877-5:2003 specifies the characteristics of the fitness for purpose of chlorinated poly(vinyl chloride) (PVC-C) ISO 15493, Plastics piping systems for industrial applications - Acrylonitrile-butadiene-styrene (ABS), ...
ISO 10508 Thermoplastics pipes and fittings for hot and cold water systems 哪位有电子版的,共享一下,谢谢啦!
