它山之石 2011/05/14
Thank you for your reply.May I know what kind of SPME did you use?Are they 50/30 micrometer DVB/CAR/PDMS?I used PDMS/DVB 65 micrometer,but I didn't get good results and I found most spectrum were impurities and no other flavor substances found. The following contents are too special to translate.
它山之石
第10楼2011/05/14
