老兵
第6楼2011/05/19
下面是编号为GBW07420土壤标准物质分析成分组成(打*者单位为%,其它为mg/kg):
【特征形态】固态 【基体】土壤 【主要分析方法】
组分 | 标准值 | 标准偏差 | |
Al2O3* | 12.28 | 0.13 | |
As | 6.3 | 0.8 | |
B | 50 | 4 | |
Ba | 524 | 37 | |
Bi | (0.17) | ||
Be | 1.9 | 0.4 | |
CaO* | 1.44 | 0.05 | |
Cd | (0.20) | ||
Cl | (50) | ||
CO2* | (0.083) | ||
Co | 12 | 2 | |
Cr | 56 | 5 | |
Cu | 23 | 4 | |
F | 383 | 74 | |
FeO* | (0.36) | ||
Ga | 15 | 2 | |
H2O+* | (2.37) | ||
Hg | 0.017 | 0.003 | |
K2O* | 2.16 | 0.02 | |
La | 38 | 4 | |
Li | 28 | 2 | |
MgO* | 1.14 | 0.08 | |
Mo | (0.68) | ||
N* | 0.029 | 0.004 | |
Nb | 14 | 1 | |
Ni | 22 | 2 | |
Pb | 19 | 2 | |
Rb | 91 | 9 | |
S* | (0.0045) | ||
Se | 0.11 | 0.06 | |
SiO2* | 72.92 | 0.26 | |
Sn | 3.2 | 0.9 | |
Sr | 227 | 7 | |
Te | (0.036) | ||
TFe2O3* | (3.78) | ||
Th | 10 | 1 | |
U | 1.9 | 0.4 | |
V | 74 | 12 | |
W | 1.5 | 0.3 | |
Y | 22 | 3 | |
Zn | 48 | 7 | |
Zr | 331 | 34 |
