kylabs
第2楼2011/05/20
有可能的,可以用这样的条件试试看,是三聚氰酸和三聚氰胺共同分离的。
Column | Cogent Diamond Hydride™, 4µm, 100A | ||||||
Catalog No. | 70000-15P-2 | ||||||
Dimensions | 2.1 x 150 mm | ||||||
Solvents | A: DI water + 0.1% acetic acid B: Acetonitrile + 0.1% acetic acid | ||||||
Gradient |
Post time | 5 min | ||||||
Flow rate | 0.4 mL/min. t0 = 0.8 min. | ||||||
Sample Prep | 1. Cyanuric acid 1.5 microg/mL: NEG (M-H)- 128.0102 m/z analyzed in Neg mode, RT = 1.278 min 2. Melamine 3 microg/mL: POS (M+H)+ 127.0727 m/z analyzed in Pos mode, RT = 11.260 min | ||||||
Detection | ESI NEG for cyanuric acid and ESI ?POS for melamine: - Agilent 6210 MSD TOF mass spectrometer. |
