芳伯氨基氮的测定
影子
第3楼2011/07/06
嗯,这样翻译是欠妥了,欧洲药典中关于稀盐酸有以下几种:
Hydrochloric acid, dilute. 1043503.
Contains 73 g/l of HCl.
Dilute 20 g of hydrochloric acid R to 100 ml with water R.
Hydrochloric acid, dilute R1. 1043504.
Contains 0.37 g/l of HCl.
Dilute 1.0 ml of dilute hydrochloric acid R to 200.0 ml with water R.
Hydrochloric acid, dilute R2. 1043505.
Dilute 30 ml of 1 M hydrochloric acid to 1000 ml with water R; adjust to pH 1.6 ± 0.1.
这样看来这里的hydrochloric acid R应该是指第一种了
中国药典的稀盐酸:取盐酸234ml,加水稀释至1000ml,即得。本液含HCl应为9.5%~10.5%。
那么在翻译主题贴时,是不是应该写成“稀盐酸(含73 g/l HCl)”?
