EP药典低密度塑料袋里Type sample 是什么
专业英语
  • Substances soluble in hexane. Place 10 g in a 250 mL conicalborosilicate-glass flask with a grou nd-glass neck. Add 100 mLof hexane R and boil under a reflux condenser for 4 h, stirringconstantly. Cool in iced water and filter rapidly through asintered-glass filter (16) (2.1.2) maintaining the solution at0 °C (t he filtration time must be less than 5 min ; if necessarythe filtration may be accelerated by applying pressure to thesolution). Evaporate 20 mL of the filtrate in a tared glass dishon a water-bath. Dry the residue in an oven at 100-105 °C for1 h. The mass of the residu e obtained is within 10 per cent ofthe residu e obt ained with the type sample and does not exceed 5 per cent.
    上面一段是EP7.0中低密度塑料袋 正己烷中的溶解:其中type sample 是指的什么?我问了EP没有标准膜,是自己找的一批样品然后一直做 Type sample 吗?
    谢谢
  • 该帖子已被版主-天晴了加5积分,加2经验;加分理由:第一个主题帖
  • 影子
    第1楼2011/07/16
    标准实样可以找供应商提供吧
