AK-47(冲)
第1楼2011/10/25
要的是这个吗?其实大学课本后面那几页都有常见的值了。我贴一点你看。
Miscellaneous Compounds
Species Phase(Matter) Chemical Formula ΔHfo (kJ/mol)
Aluminum
Aluminum Solid Al 0
Aluminum Chloride Solid AlCl3 -705.63
Aluminum Oxide Solid Al2O3 -1675.7
Barium
Barium Chloride Solid BaCl2 -858.6
Barium Carbonate Solid BaCO3 -1213
Barium Oxide Solid BaO -548.1
Barium Sulfate Solid BaSO4 -1473.2
Beryllium
Beryllium Solid Be 0
Beryllium Hydroxide Solid Be(OH)2 -902.5
Boron
Boron Trichloride Solid BCl3 -402.96
Bromine
Bromine Liquid Br2 0
Bromine Gas Br 111.884
Bromine Gas Br2 30.91
Bromine Trifluoride Gas BrF3 -255.60
Hydrobromic Acid Gas HBr -36.29
Calcium
Calcium Solid Ca 0
Calcium Gas Ca 178.2
Calcium(II) Ion Gas Ca2+ 1925.90
Calcium carbide Solid CaC2 -59.8
Calcium Carbonate(Calcite) Solid CaCO3 -1207.6
Calcium Chloride Solid CaCl2 -795.8
Calcium Phosphate Solid Ca3(PO4)2 -4132
Calcium Fluoride Solid CaF2 -1219.6
Calcium Hydride Solid CaH2 -186.2
Calcium hydroxide Solid Ca(OH)2 -986.09
Calcium hydroxide Aqueous Ca(OH)2 -1002.82
Calcium Oxide Solid CaO -635.09
Calcium Sulfate Solid CaSO4 -1434.52
Calcium Sulfide Solid CaS -482.4
Carbon Alkanes Above
Benzene Liquid C6H6 48.95
Benzoic acid Solid C7H6O2 -385.2
Carbon(Graphite) Solid C 0
Carbon(Diamond) Solid C 1.8
Carbon Gas C 716.67
Carbon Dioxide Gas CO2 -393.509
Carbon disulfide Liquid CS2 89.41
Carbon disulfide Gas CS2 116.7
Carbon Monoxide Gas CO -110.525
Carbon Tetrachloride Liquid CCl4 -139.5
Carbon Tetrachloride Gas CCl4 -103.18
Carbonyl Chloride(Phosgene) Gas COCl2 -218.8
Ethane Gas C2H6 -83.85
Ethanol Liquid C2H5OH -277.0
Ethanol Gas C2H5OH -235.3
Ethene Gas C2H4 52.47
Ethyne Gas C2H2 226.73
Methane Gas CH4 -74.87
Methanol(Methyl Alcohol) Liquid CH3OH -238.4
Methanol(Methyl Alcohol) Gas CH3OH -201.0
Methyl Trichloride(Chloroform) Liquid CHCl3 -134.47
Methyl Trichloride(Chloroform) Gas CHCl3 -103.18
Propane Liquid C3H8 -104.7
Caesium
Caesium Solid Cs 0
Caesium(I) ion Gas Cs+ 457.964
Caesium chloride Solid CsCl -443.04
Chlorine
Chlorine Gas Cl2 0
Chromium
Chromium Solid Cr 0
Copper
Copper Solid Cu 0
Fluorine
Fluorine Gas F2 0
Hydrogen
Hydrogen Gas H2 0
Water Liquid H2O -285.83
Water Gas H2O -241.83
Hydrogen Peroxide Liquid H2O2 -187.78
Hydrogen Cyanide Gas HCN +130.5
Hydrogen Iodide Gas HI +26.5
Hydrofluoric acid Gas HF -269
Hydrochloric acid Gas HCl -92.30
Iodine
Iodine Solid I2 0
Iodine Gas I2 62.438
Iron
Lead
Lithium
Magnesium
Magnesium Carbonate Solid MgCO3 -1111.69
Magnesium Chloride Solid MgCl2 -641.8
Magnesium hydroxide Solid Mg(OH)2 -924.54
Magnesium Oxide Solid MgO -601.24
Magnesium sulfate Solid MgSO4 -1278.2
Manganese
Manganese(II) Oxide Solid MnO -384.9
Manganese(IV) Oxide Solid MnO2 -519.7
Mercury
Mercury(II) Oxide (red) Solid HgO -90.83
Mercury Sulfide (red, cinnabar) Solid HgS -58.2
Nickel
Nitrogen
Ammonia Aqueous NH3 -80.8
Ammonia Gas NH3 -45.90
Nitrogen Dioxide Gas NO2 33.1
Nitrogen Monoxide Gas NO 90.29
Oxygen
Monoatomic oxygen Gas O 249
Ozone Gas O3 143
Phosphorus
Phosphorus trichloride Liquid PCl3 -320
Phosphorus pentachloride Solid PCl5 -440
Potassium
Potassium Bromide Solid KBr -392.2
Potassium Chlorate Solid KClO3 -397.73
Potassium chloride Solid KCl -436.68
Potassium Fluoride Solid KF -562.6
Potassium Perchlorate Solid KClO4 -430.12
Silicon
Silica (Quartz) Solid SiO2 -910.86
Silver
Silver Bromide Solid AgBr -99.5
Silver Chloride Solid AgCl -127.01
Silver Iodide Solid AgI -62.4
Silver Oxide Solid Ag2O -31.1
Silver Sulfide Solid Ag2S -31.8
Sodium
Sodium Carbonate Solid Na2CO3 -1130.77
Sodium chloride Aqueous NaCl -407.27
Sodium chloride Solid NaCl -411.12
Sodium chloride Liquid NaCl -385.92
Sodium chloride Gas NaCl -181.42
Sodium Fluoride Solid NaF -569.0
Sodium Hydroxide Aqueous NaOH -469.15
Sodium Hydroxide Solid NaOH -425.93
Sodium nitrate Aqueous NaNO3 -446.2
Sodium nitrate Solid NaNO3 -424.8
Sulfur
Hydrogen Sulfide Gas H2S -20.63
Sulfur Dioxide Gas SO2 -296.84
Sulfuric acid Liquid H2SO4 -814
Tin
Titanium
Zinc
