天晴了
第7楼2011/09/14
I wanted to be a PHD student when I was a little girl. But I chose pharmaceutical engineering as my major accidentally and I have to learn Chemistry. I do not like chemistry at all and failed to be a Master in Analytical Chemistry. As a result, I have no opportunity to be a PHD.
poorlittle
第9楼2011/09/14
The term "philosophy" does not refer solely to the modern field of philosophy, but is used in a broader sense in accordance with its original Greek meaning, which is "love of wisdom". In most of Europe, all fields other than theology, law and medicine were traditionally known as philosophy.
(from http://en.wikipedia.org/wiki/Doctor_of_Philosophy )
