醋老西
第1楼2006/03/08
中性变载 nentral loading
拉抻失稳 instability in tension
加速度波 acceleration wave
本构方程 constitutive equation
完全解 complete solution
名义应力 nominal stress
过应力 over-stress
真应力 true stress
等效应力 equivalent stress
流动应力 flow stress
应力间断 stress discontinuity
应力空间 stress space
主应力空间 principal stress space
静水应力状态 hydrostatic state of stress
对数应变 logarithmic strain
工程应变 engineering strain
等效应变 equivalent strain
应变局部化 strain localization
应变率 strain rate
应变率敏感性 strain rate sensitivity
应变空间 strain space
有限应变 finite strain
塑性应变增量 plastic strain increment
累积塑性应变 accumulated plastic strain
永久变形 permanent deformation
内变量 internal variable
应变软化 strain-softening
理想刚塑性材料 rigid-perfectly plastic Material
刚塑性材料 rigid-plastic material
理想塑性材料 perfectl plastic material
材料稳定性 stability of material
应变偏张量 deviatoric tensor of strain
应力偏张量 deviatori tensor of stress
应变球张量 spherical tensor of strain
应力球张量 spherical tensor of stress
路径相关性 path-dependency
线性强化 linear strain-hardening
应变强化 strain-hardening
随动强化 kinematic hardening
各向同性强化 isotropic hardening
强化模量 strain-hardening modulus
幂强化 power hardening
塑性极限弯矩 plastic limit bending Moment
塑性极限扭矩 plastic limit torque
弹塑性弯曲 elastic-plastic bending
弹塑性交界面 elastic-plastic interface
弹塑性扭转 elastic-plastic torsion
粘塑性 Viscoplasticity
非弹性 Inelasticity
理想弹塑性材料 elastic-perfectly plastic Material
极限分析 limit analysis
极限设计 limit design
极限面 limit surface
上限定理 upper bound theorem
上屈服点 upper yield point
下限定理 lower bound theorem
下屈服点 lower yield point
界限定理 bound theorem
初始屈服面 initial yield surface
后继屈服面 subsequent yield surface
屈服面[的]外凸性 convexity of yield surface
截面形状因子 shape factor of cross-section
沙堆比拟 sand heap analogy
屈服 Yield
屈服条件 yield condition
屈服准则 yield criterion
屈服函数 yield function
屈服面 yield surface
塑性势 plastic potential
能量吸收装置 energy absorbing device
能量耗散率 energy absorbing device
塑性动力学 dynamic plasticity
塑性动力屈曲 dynamic plastic buckling
塑性动力响应 dynamic plastic response
塑性波 plastic wave
运动容许场 kinematically admissible Field
静力容许场 statically admissible Field
流动法则 flow rule
速度间断 velocity discontinuity
滑移线 slip-lines
滑移线场 slip-lines field
移行塑性铰 travelling plastic hinge
塑性增量理论 incremental theory of Plasticity
米泽斯屈服准则 Mises yield criterion
普朗特--罗伊斯关系 prandtl- Reuss relation
特雷斯卡屈服准则 Tresca yield criterion
洛德应力参数 Lode stress parameter
莱维--米泽斯关系 Levy-Mises relation
亨基应力方程 Hencky stress equation
赫艾--韦斯特加德应力空间 Haigh-Westergaard stress space
洛德应变参数 Lode strain parameter
德鲁克公设 Drucker postulate
盖林格速度方程 Geiringer velocity Equation
结构力学 structural mechanics
结构分析 structural analysis
结构动力学 structural dynamics
拱 Arch
三铰拱 three-hinged arch
抛物线拱 parabolic arch
圆拱 circular arch
穹顶 Dome
空间结构 space structure
空间桁架 space truss
雪载[荷] snow load
风载[荷] wind load
土压力 earth pressure
地震载荷 earthquake loading
弹簧支座 spring support
支座位移 support displacement
支座沉降 support settlement
超静定次数 degree of indeterminacy
机动分析 kinematic analysis
结点法 method of joints
截面法 method of sections
结点力 joint forces
醋老西
第2楼2006/03/08
共轭位移 conjugate displacement
影响线 influence line
三弯矩方程 three-moment equation
单位虚力 unit virtual force
刚度系数 stiffness coefficient
柔度系数 flexibility coefficient
力矩分配 moment distribution
力矩分配法 moment distribution method
力矩再分配 moment redistribution
分配系数 distribution factor
矩阵位移法 matri displacement method
单元刚度矩阵 element stiffness matrix
单元应变矩阵 element strain matrix
总体坐标 global coordinates
贝蒂定理 Betti theorem
高斯--若尔当消去法 Gauss-Jordan elimination Method
屈曲模态 buckling mode
复合材料力学 mechanics of composites
复合材料 composite material
纤维复合材料 fibrous composite
单向复合材料 unidirectional composite
泡沫复合材料 foamed composite
颗粒复合材料 particulate composite
层板 Laminate
夹层板 sandwich panel
正交层板 cross-ply laminate
斜交层板 angle-ply laminate
层片 Ply
多胞固体 cellular solid
膨胀 Expansion
压实 Debulk
劣化 Degradation
脱层 Delamination
脱粘 Debond
纤维应力 fiber stress
层应力 ply stress
层应变 ply strain
层间应力 interlaminar stress
比强度 specific strength
强度折减系数 strength reduction factor
强度应力比 strength -stress ratio
横向剪切模量 transverse shear modulus
横观各向同性 transverse isotropy
正交各向异 Orthotropy
剪滞分析 shear lag analysis
短纤维 chopped fiber
长纤维 continuous fiber
纤维方向 fiber direction
纤维断裂 fiber break
纤维拔脱 fiber pull-out
纤维增强 fiber reinforcement
致密化 Densification
最小重量设计 optimum weight design
网格分析法 netting analysis
混合律 rule of mixture
失效准则 failure criterion
蔡--吴失效准则 Tsai-W u failure criterion
达格代尔模型 Dugdale model
断裂力学 fracture mechanics
概率断裂力学 probabilistic fracture Mechanics
格里菲思理论 Griffith theory
线弹性断裂力学 linear elastic fracture mechanics, LEFM
弹塑性断裂力学 elastic-plastic fracture mecha-nics, EPFM
断裂 Fracture
脆性断裂 brittle fracture
解理断裂 cleavage fracture
蠕变断裂 creep fracture
延性断裂 ductile fracture
晶间断裂 inter-granular fracture
准解理断裂 quasi-cleavage fracture
穿晶断裂 trans-granular fracture
裂纹 Crack
裂缝 Flaw
缺陷 Defect
割缝 Slit
微裂纹 Microcrack
折裂 Kink
椭圆裂纹 elliptical crack
深埋裂纹 embedded crack
[钱]币状裂纹 penny-shape crack
预制裂纹 Precrack
短裂纹 short crack
表面裂纹 surface crack
裂纹钝化 crack blunting
裂纹分叉 crack branching
裂纹闭合 crack closure
裂纹前缘 crack front
裂纹嘴 crack mouth
裂纹张开角 crack opening angle,COA
裂纹张开位移 crack opening displacement,COD
裂纹阻力 crack resistance
裂纹面 crack surface
裂纹尖端 crack tip
裂尖张角 crack tip opening angle,CTOA
裂尖张开位移 crack tip opening displacement, CTOD
裂尖奇异场 crack tip singularity Field
裂纹扩展速率 crack growth rate
稳定裂纹扩展 stable crack growth
定常裂纹扩展 steady crack growth
亚临界裂纹扩展 subcritical crack growth
裂纹[扩展]减速 crack retardation
止裂 crack arrest
止裂韧度 arrest toughness
断裂类型 fracture mode
滑开型 sliding mode
张开型 opening mode
撕开型 tearing mode
复合型 mixed mode
撕裂 Tearing
撕裂模量 tearing modulus
断裂准则 fracture criterion
J积分 J-integral
J阻力曲线 J-resistance curve
断裂韧度 fracture toughness
应力强度因子 stress intensity factor
HRR场 Hutchinson-Rice-Rosengren Field
守恒积分 conservation integral
有效应力张量 effective stress tensor
应变能密度 strain energy density
能量释放率 energy release rate
内聚区 cohesive zone
塑性区 plastic zone
张拉区 stretched zone
热影响区 heat affected zone, HAZ
延脆转变温度 brittle-ductile transition tempe-rature
剪切带 shear band
剪切唇 shear lip
无损检测 non-destructive inspection
双边缺口试件 double edge notched specimen, DEN specimen
单边缺口试件 single edge notched specimen, SEN specimen
三点弯曲试件 three point bending specimen, TPB specimen
中心裂纹拉伸试件 center cracked tension specimen, CCT specimen
中心裂纹板试件 center cracked panel specimen, CCP specimen
紧凑拉伸试件 compact tension specimen,CT specimen
大范围屈服 large scale yielding
小范围攻屈服 small scale yielding
韦布尔分布 Weibull distribution
帕里斯公式 paris formula
空穴化 Cavitation
应力腐蚀 stress corrosion
概率风险判定 probabilistic risk assessment, PRA
损伤力学 damage mechanics
损伤 Damage
连续介质损伤力学 continuum damage mechanics
细观损伤力学 microscopic damage mechanics
累积损伤 accumulated damage
脆性损伤 brittle damage
延性损伤 ductile damage
宏观损伤 macroscopic damage
细观损伤 microscopic damage
微观损伤 microscopic damage
损伤准则 damage criterion
损伤演化方程 damage evolution equation
损伤软化 damage softening
损伤强化 damage strengthening
损伤张量 damage tensor
损伤阈值 damage threshold
损伤变量 damage variable
损伤矢量 damage vector
损伤区 damage zone
醋老西
第3楼2006/03/08
疲劳 Fatigue
低周疲劳 low cycle fatigue
应力疲劳 stress fatigue
随机疲劳 random fatigue
蠕变疲劳 creep fatigue
腐蚀疲劳 corrosion fatigue
疲劳损伤 fatigue damage
疲劳失效 fatigue failure
疲劳断裂 fatigue fracture
疲劳裂纹 fatigue crack
疲劳寿命 fatigue life
疲劳破坏 fatigue rupture
疲劳强度 fatigue strength
疲劳辉纹 fatigue striations
疲劳阈值 fatigue threshold
交变载荷 alternating load
交变应力 alternating stress
应力幅值 stress amplitude
应变疲劳 strain fatigue
应力循环 stress cycle
应力比 stress ratio
安全寿命 safe life
过载效应 overloading effect
循环硬化 cyclic hardening
循环软化 cyclic softening
环境效应 environmental effect
裂纹片 crack gage
裂纹扩展 crack growth, crack Propagation
裂纹萌生 crack initiation
循环比 cycle ratio
实验应力分析 experimental stress Analysis
工作[应变]片 active[strain] gage
基底材料 backing material
应力计 stress gage
零[点]飘移 zero shift, zero drift
应变测量 strain measurement
应变计 strain gage
应变指示器 strain indicator
应变花 strain rosette
应变灵敏度 strain sensitivity
机械式应变仪 mechanical strain gage
直角应变花 rectangular rosette
引伸仪 Extensometer
应变遥测 telemetering of strain
横向灵敏系数 transverse gage factor
横向灵敏度 transverse sensitivity
焊接式应变计 weldable strain gage
平衡电桥 balanced bridge
粘贴式应变计 bonded strain gage
粘贴箔式应变计 bonded foiled gage
粘贴丝式应变计 bonded wire gage
桥路平衡 bridge balancing
电容应变计 capacitance strain gage
补偿片 compensation technique
补偿技术 compensation technique
基准电桥 reference bridge
电阻应变计 resistance strain gage
温度自补偿应变计 self-temperature compensating gage
半导体应变计 semiconductor strain Gage
集流器 slip ring
应变放大镜 strain amplifier
疲劳寿命计 fatigue life gage
电感应变计 inductance [strain] gage
光[测]力学 Photomechanics
光弹性 Photoelasticity
光塑性 Photoplasticity
杨氏条纹 Young fringe
双折射效应 birefrigent effect
等位移线 contour of equal Displacement
暗条纹 dark fringe
条纹倍增 fringe multiplication
干涉条纹 interference fringe
等差线 Isochromatic
等倾线 Isoclinic
等和线 isopachic
应力光学定律 stress- optic law
主应力迹线 Isostatic
亮条纹 light fringe
光程差 optical path difference
热光弹性 photo-thermo -elasticity
光弹性贴片法 photoelastic coating Method
光弹性夹片法 photoelastic sandwich Method
动态光弹性 dynamic photo-elasticity
空间滤波 spatial filtering
空间频率 spatial frequency
起偏镜 Polarizer
反射式光弹性仪 reflection polariscope
残余双折射效应 residual birefringent Effect
应变条纹值 strain fringe value
应变光学灵敏度 strain-optic sensitivity
应力冻结效应 stress freezing effect
应力条纹值 stress fringe value
应力光图 stress-optic pattern
暂时双折射效应 temporary birefringent Effect
脉冲全息法 pulsed holography
透射式光弹性仪 transmission polariscope
实时全息干涉法 real-time holographic interfero - metry
网格法 grid method
全息光弹性法 holo-photoelasticity
全息图 Hologram
全息照相 Holograph
全息干涉法 holographic interferometry
全息云纹法 holographic moire technique
全息术 Holography
全场分析法 whole-field analysis
散斑干涉法 speckle interferometry
散斑 Speckle
错位散斑干涉法 speckle-shearing interferometry, shearography
散斑图 Specklegram
白光散斑法 white-light speckle method
云纹干涉法 moire interferometry
[叠栅]云纹 moire fringe
[叠栅]云纹法 moire method
云纹图 moire pattern
离面云纹法 off-plane moire method
参考栅 reference grating
试件栅 specimen grating
分析栅 analyzer grating
面内云纹法 in-plane moire method
脆性涂层法 brittle-coating method
条带法 strip coating method
坐标变换 transformation of Coordinates
计算结构力学 computational structural mecha-nics
加权残量法 weighted residual method
有限差分法 finite difference method
有限[单]元法 finite element method
配点法 point collocation
里茨法 Ritz method
广义变分原理 generalized variational Principle
最小二乘法 least square method
胡[海昌]一鹫津原理 Hu-Washizu principle
赫林格-赖斯纳原理 Hellinger-Reissner Principle
修正变分原理 modified variational Principle
约束变分原理 constrained variational Principle
混合法 mixed method
杂交法 hybrid method
边界解法 boundary solution method
有限条法 finite strip method
半解析法 semi-analytical method
协调元 conforming element
非协调元 non-conforming element
混合元 mixed element
杂交元 hybrid element
边界元 boundary element
强迫边界条件 forced boundary condition
自然边界条件 natural boundary condition
离散化 Discretization
离散系统 discrete system
连续问题 continuous problem
广义位移 generalized displacement
广义载荷 generalized load
广义应变 generalized strain
广义应力 generalized stress
界面变量 interface variable
节点 node, nodal point
[单]元 Element
角节点 corner node
边节点 mid-side node
内节点 internal node
无节点变量 nodeless variable
醋老西
第4楼2006/03/08
杆元 bar element
桁架杆元 truss element
梁元 beam element
二维元 two-dimensional element
一维元 one-dimensional element
三维元 three-dimensional element
轴对称元 axisymmetric element
板元 plate element
壳元 shell element
厚板元 thick plate element
三角形元 triangular element
四边形元 quadrilateral element
四面体元 tetrahedral element
曲线元 curved element
二次元 quadratic element
线性元 linear element
三次元 cubic element
四次元 quartic element
等参[数]元 isoparametric element
超参数元 super-parametric element
亚参数元 sub-parametric element
节点数可变元 variable-number-node element
拉格朗日元 Lagrange element
拉格朗日族 Lagrange family
巧凑边点元 serendipity element
巧凑边点族 serendipity family
无限元 infinite element
单元分析 element analysis
单元特性 element characteristics
刚度矩阵 stiffness matrix
几何矩阵 geometric matrix
等效节点力 equivalent nodal force
节点位移 nodal displacement
节点载荷 nodal load
位移矢量 displacement vector
载荷矢量 load vector
质量矩阵 mass matrix
集总质量矩阵 lumped mass matrix
相容质量矩阵 consistent mass matrix
阻尼矩阵 damping matrix
瑞利阻尼 Rayleigh damping
刚度矩阵的组集 assembly of stiffness Matrices
载荷矢量的组集 consistent mass matrix
质量矩阵的组集 assembly of mass matrices
单元的组集 assembly of elements
局部坐标系 local coordinate system
局部坐标 local coordinate
面积坐标 area coordinates
体积坐标 volume coordinates
曲线坐标 curvilinear coordinates
静凝聚 static condensation
合同变换 contragradient transformation
形状函数 shape function
试探函数 trial function
检验函数 test function
权函数 weight function
样条函数 spline function
代用函数 substitute function
降阶积分 reduced integration
零能模式 zero-energy mode
P收敛 p-convergence
H收敛 h-convergence
掺混插值 blended interpolation
等参数映射 isoparametric mapping
双线性插值 bilinear interpolation
小块检验 patch test
非协调模式 incompatible mode
节点号 node number
单元号 element number
带宽 band width
带状矩阵 banded matrix
变带状矩阵 profile matrix
带宽最小化 minimization of band width
波前法 frontal method
子空间迭代法 subspace iteration method
行列式搜索法 determinant search method
逐步法 step-by-step method
纽马克 法 Newmark
威尔逊 法 Wilson
拟牛顿法 quasi-Newton method
牛顿-拉弗森法 Newton-Raphson method
增量法 incremental method
初应变 initial strain
初应力 initial stress
切线刚度矩阵 tangent stiffness matrix
割线刚度矩阵 secant stiffness matrix
模态叠加法 mode superposition method
平衡迭代 equilibrium iteration
子结构 Substructure
子结构法 substructure technique
超单元 super-element
网格生成 mesh generation
结构分析程序 structural analysis program
前处理 pre-processing
后处理 post-processing
网格细化 mesh refinement
应力光顺 stress smoothing
组合结构 composite structure
