junmyliu
第4楼2012/01/09
LZ所说的就是塑料中重金属特殊迁移(specific migration)
根据EU 10/2011 特殊迁移与全迁移(globle migration or overall migration)条件选择是不一样的(温度和时间)全迁移只有7种条件可以选择
特殊迁移可以有很多种
其条件选择如下:
1、特殊迁移 EU 10/2011 页码 L12/83
Table 1
Contact time
Contact time in worst foreseeable use
Test time
t ≤ 5 min
5 min
5 min < t ≤ 0,5 hour
0,5 hour
0,5 hours < t ≤ 1 hour
1 hour
1 hour < t ≤ 2 hours
2 hours
2 hours < t ≤ 6 hours
6 hours
6 hours < t ≤ 24 hours
24 hours
1 day < t ≤ 3 days
3 days
3 days < t ≤ 30 days
10 days
Above 30 days
See specific conditions
Table 2
Contact temperature
Conditions of contact in worst foreseeable use
Test conditions
Contact temperature
Test temperature
T ≤ 5 °C
5 °C
5 °C < T ≤ 20 °C
20 °C
20 °C < T ≤ 40 °C
40 °C
40 °C < T ≤ 70 °C
70 °C
70 °C < T ≤ 100 °C
100 °C or reflux temperature
100 °C < T ≤ 121 °C
121 °C (*)
121 °C < T ≤ 130 °C
130 °C (*)
130 °C < T ≤ 150 °C
150 °C (*)
150 °C < T < 175 °C
175 °C (*)
T > 175 °C
Adjust the temperature to the real temperature at the interface with the food (*)
This temperature shall be used only for food simulants D2 and E. For applications heated under pressure migration testing under pressure at the relevant temperature may be performed. For food simulants A, B, C or D1 the test may be replaced by a test at 100 °C or at reflux temperature for duration of four times the time selected according to the conditions in Table 1.
2、全迁移 EU 10/2011 页码 L12/86
Table 3
Standardised testing conditions
Column 1
Column 2
Column 3
Test number
Contact time in days [d] or hours [h] at Contact temperature in [°C]
Intended food contact conditions
OM1
10 d at 20 °C
Any food contact at frozen and refrigerated conditions.
OM2
10 d at 40 °C
Any long term storage at room temperature or below, including heating up to 70 °C for up to 2 hours, or heating up to 100 °C for up to 15 minutes.
OM3
2 h at 70 °C
Any contact conditions that include heating up to 70 °C for up to 2 hours, or up to 100 °C for up to 15 minutes, which are not followed by long term room or refrigerated temperature storage.
OM4
1 h at 100 °C
High temperature applications for all food simulants at temperature up to 100 °C.
OM5
2 h at 100 °C or at reflux or alternatively 1 h at 121 °C
High temperature applications up to 121 °C.
OM6
4 h at 100 °C or at reflux
Any food contact conditions with food simulants A, B or C, at temperature exceeding 40 °C.
OM7
2 h at 175 °C
High temperature applications with fatty foods exceeding the conditions of OM5.
针对LZ的条件 再依据EU10/2011 特殊迁移的选择条件
应该用3%醋酸40度浸泡3天,3天后取出浸泡液上机测试重金属(Ba、Co、Cu、Fe、Li、Mn、Zn)含量 单位 mg/kg
