万古霉素的液相检测
兽药/抗生素检测
  • 万古霉素的液相检测条件,很难做的一个东西,这个条件也可以用于液质
    ColumnCogent Diamond Hydride™, 4µm, 100A
    Catalog No.70000-7.5P
    Dimensions4.6 x 75 mm
    Solvents
    A:DI H2O/ 0.1% formic acid
    B:Acetonitrile/ 0.1% formic acid
    Gradient
    time (min.)%B
    070
    610
    770
    Post Time2 min
    Injection Vol.5 microL
    Flow rate1.0 mL/min.
    DetectionUV 210 nm
    SampleStock Solution: 1 mg/mL vancomycin HCl in 50/50 solvent A/solvent B diluent. The solution was filtered through a 0.45 µm nylon syringe filter (MicroSolv Tech Corp).
    Working Solution: Stock solution was diluted 1:100 with 50/50 solvent A/solvent B mixture.
    PeakVancomycin
    t00.9 min
  • qzxmsy
    第1楼2015/03/26
    有哪位大侠可以将资料翻译成中文吗?
  • hujiangtao
    第2楼2015/04/01
    不好提取 回收很低
