Each capsule contains 100mg of specialized bacterial cultures for use in a broad range of areas involving degradation of industrial and municipal waste
To use, mix capsule contents with 0.5L of APHA standard dilution water at 20°C (68°F), stir for at least 60 minutes
Mixture yields seed inoculum for up to 200 BOD tests
For best results, use within one year of purchase
Also available as Polyseed-NX, which contains an approved chemical additive for the inhibition of ammonia nitrogen (NH3-N) in wastewater samples (CBOD) 美国环保署 认可的BOD接种剂,是测试结果保持稳定。
