容百川
第1楼2012/03/28
I tried to translate as following:
Based on new situations of development in environment monitoring field at home and abroad, it is detailed analyzed that organic pollutants in water quality, the rural environmentand ecological environment will be monitored in future in our national environmental monitoring field. And organic pollutants monitoring in water quality, rural environmental monitoring and ecological environment monitoring are discussed in depth respectively.
