色谱杂质峰分不开
厂商论坛
  • 峰重叠,我试过了好多C18的柱子,都是重叠的。我想问问,对于这两种化合物,根据结构应该选取什么柱子会好一点,或者在选用C18柱子流动相该如何考虑。谢谢。
    Solution A— Prepare a mixture of Diluted acetic acid, methanol, and acetonitrile (60:35:5).
    Solution B— Prepare a mixture of methanol, Diluted acetic acid, and acetonitrile (80:15:5).
    chromatograph is equipped with a 250-nm detector, a refrigerated autosamplerat 5, and a 4.6-mm × 25-cm column that contains5-µm packing L1. The flow rate is about 1 mL per minute. The column temperatureis maintained at 40. The chromatograph is programmed as follows.
  • lixuesw
    第3楼2012/04/17
    哎 还期待着答案呢 图一直不出来
    xiongbb(xiongbb) 发表:图挂了.....
