给力芬
第1楼2012/08/23
http://bbs.instrument.com.cn/shtml/20120426/4000193/,这是我发的帖子,希望可以帮到你
孚光精仪
第3楼2017/08/07
非偏振片光束分光镜采用多层镀膜技术,损伤阈值高达 6 J/cm2.这款非偏振分光镜与传统的非偏振分光立方体相比,透过率更高,激光损伤阈值更高,表现更为优异,因为传统的非偏振立方体存在约 10 %,的激光功率能量损失且易损伤镀膜。
Rs 和Rp的偏振分离约为5%,非常适合非偏振光和其它任何偏振态的激光使用。
这款非偏振分光镜标准品具有几十纳米镀膜带宽,这使得一个镜片可以多个激光波长使用,大大节约了使用成本,例如,非偏振片分光镜的镀膜带宽 1025 nm - 1095 nm ,可以用于Yb:KGW, Yb:YAG, Nd:YAG, Yb:Glass, Nd:Glass激光中
标准款非偏振片分光镜参数
Diameter tolerance | +0/-0.1 mm |
Thickness tolerance | ±0.1 mm |
Clear aperture | >90% |
Surface quality | 20-10 S-D |
Transmitted wavefront distortion | λ/8 @ 632.8 nm |
Separation of polarizations, Rs-Rp | <5% |
Coating on S2 | ARsp<0.75% |
Protective chamfers | <0.25 mm x 45° |
Coating adhesion and durability | Per MIL-C-675A |
Substrate material | Substrate size | Reflectivity Rsp, % | Angle of incidence, deg | Rs-Rp | Wavelength, nm | Product ID |
UVFS | Ø25.4 x 5 mm | 50+/-5 | 45 | 5% | 1025 - 1095 (GDD< 100 fs^2) | 1-OS-2-0254-5- |
UVFS | Ø25.4 x 5 mm | 50+/-5 | 45 | 5% | 390 - 410 (GDD< 20 fs^2) | 1-OS-2-0254-5- |
UVFS | Ø25.4 x 5 mm | 50+/-5 | 45 | 5% | 770 - 830 (GDD< 75 fs^2) | 1-OS-2-0254-5- |
UVFS | Ø25.4 x 5 mm | 50+/-5 | 45 | 5% | 355 | 1-OS-2-0254-5- |
UVFS | Ø25.4 x 5 mm | 50+/-5 | 45 | 5% | 515-532 | 1-OS-2-0254-5- |
UVFS | 20 x 40 x 5 mm | 50+/-5 | 45 | 5% | 355 | 1-OS-2-2040-5- |
UVFS | 20 x 40 x 5 mm | 50+/-5 | 45 | 5% | 390 - 410 (GDD< 20 fs^2) | 1-OS-2-2040-5- |
UVFS | 20 x 40 x 5 mm | 50+/-5 | 45 | 5% | 515-532 | 1-OS-2-2040-5-[4D45-50 |
BK7 | Ø25.4 x 6 mm | 50+/-5 | 45 | 5% | 633 | 1-OS-1-0254-6- |
BK7 | 20 x 40 x 5 mm | 50+/-5 | 45 | 5% | 633 | 1-OS-2-2040-5- |
UVFS | 20 x 40 x 5 mm | 50+/-5 | 45 | 5% | 770 - 830 (GDD< 75 fs^2) | 1-OS-2-2040-5- |
UVFS | 20 x 40 x 5 mm | 50+/-5 | 45 | 5% | 1025 - 1095 (GDD< 100 fs^2) | 1-OS-2-2040-5- |
BK7 | Ø25.4 x 6 mm | 50+/-5 | 45 | 5% | 1530- 1540 | 1-OS-1-0254-6- |
BK7 | 20 x 40 x 5 mm | 50+/-5 | 45 | 5% | 1530- 1540 | 1-OS-2-2040-5- |
