65.1 高效液相色谱法测定硝呋太尔片的含量
  • qq250083771
    2012/08/27
厂商论坛
  • 【作者】 王亚洲; 梁陈方;
    【Author】 Wang Yazhou,Liang Chenfang (No.4 Affiliated Hospital of Guangxi Medical University, Liuzhou, Guangxi,China 545005)
    【机构】 广西医科大学第四附属医院; 广西医科大学第四附属医院 广西柳州545005; 广西柳州545005;
    【摘要】 目的建立测定硝呋太尔片含量的高效液相色谱(HPLC)法。方法色谱柱为DiamonsilC18柱(250mm×4.6mm,5μm),流动相为甲醇-水(50∶50),流速为1.0mL/min,柱温为30℃,检测波长为260nm。结果硝呋太尔的质量浓度在50.15~300.9μg/mL范围内与峰面积线性关系良好(r=0.9999,n=6),平均加样回收率为101.2%,RSD=1.8%(n=6)。结论HPLC法简便易行、准确可靠,可作为硝呋太尔片的含量测定方法。 更多还原
    【Abstract】 Objective To establish a HPLC method for the content determination of nifuratel tablet.Methods The determination was performed on Diamonsil C18 column under 30℃ ; the mobile phase consisted of methanol-water (50 ∶ 50) with the flow rate of 1.0 mL/min, the detecting wavelength at 260 nm.Results The calibration curve of nifuratel was linear from 50.15-300.9 μ g/mL (r=0.999 9, n=6), the average recovery rate and relative standard deviation were 101.2% and 1.8% (n=6) respectively.Conclusion The meth... 更多还原
    【关键词】 硝呋太尔; 含量测定; 高效液相色谱法;
    【Key words】 nifuratel; content determination; HPLC;
