会飞的猪猪
第1楼2012/12/15
206.2 Isolation;identification and characterization of an algicidal bacterium from Lake Taihu and preliminary studies on its algicidal compounds
Chuan Tian, Xianglong Liu, Jing Tan, Shengqin Lin, Daotang Li, Hong Yang*
State Key Laboratory of Microbial metabolism, School of Life Science and Biotechnology, Shanghai Jiao Tong University, 800 Dongchuan Rd. Shanghai 200240, China.
Abstract In an effort to identify a bio-agent capable of controlling cyanobacterial blooms, we isolated a bacterial strain, A27, which exhibited strong algicidal activity against the dominant bloom-forming species of Microcystis aeruginosa in Lake Taihu. Based on 16s rRNA gene sequence analysis, this strain belongs to the genus Exiguobacterium. This is the first report of an algicidal bacterial strain belonging to the genus Exiguobacterium. Strain A27 exhibited algicidal activity against a broad range of cyanobacteria, but elicited little or no algicidal activity against the two green algal strains tested. The algicidal activity of strain A27 was shown to be dependent on the density of the bacteria and to have a threshold density of 1.5×106 CFU/mL. Our data also showed that the algicidal activity of strain A27 depended on different growth stages of Microcystis aeruginosa (exponential ≈ lag phase > early stationary) rather than that of the bacterium itself. Our results also suggested the algicidal activity of strain A27 occurred via the production of extracellular algicidal compounds. Investigation of the algicidal compounds revealed that there were at least two different algicidal compounds produced by strain A27. These results indicated that strain A27 has great potential for use in the control of outbreaks of cyanobacterial blooms in Lake Taihu.
Key words: algicidal bacteria; freshwater cyanobacterial bloom; Microcystis aeruginosa; Exiguobacterium sp. A27; algicidal compounds
会飞的猪猪
第2楼2012/12/15
206.3 纯种固态工艺酿造醋的风味研究
刘超 鲁梅芳 王春玲 侯丽华
【作者单位】: 天津科技大学教育部食品营养与安全重点实验室;
【摘要】:通过对纯种固态酿醋工艺的有机酸、氨基酸和香气物质变化情况进行跟踪分析,系统全面地研究了纯种固态酿醋工艺的风味变化情况,为今后改善其风味奠定基础。食醋中的有机酸主要为乙酸、琥珀酸、苹果酸和乳酸。本工艺下食醋醋醅结束样中的氨基酸总量为501.52mg/L,总量比酒醅结束样增加了3倍左右,甜味氨基酸的含量从28.97mg/L增加到256.12mg/L。通过固相微萃取和气质联用技术对食醋酿造过程中香气成分进行分析发现酯类在第14d累积到最大值,之后略有下降;醇类在酒精发酵阶段大量生成,在醋酸发酵阶段由于与酸类酯化而大量减少;酸类在醋酸发酵阶段大量生成,之后由于酯化速度大于生酸速度而产生相对含量下降的趋势。
【关键词】: 纯种固态酿醋工艺 风味 氨基酸 香气
注意:该文献莫有图谱
会飞的猪猪
第3楼2012/12/15
206.4 盐酸哌甲酯缓释微丸的制备及处方优化
吴娟 丁雪鹰 高静 高申
【作者单位】: 第二军医大学药学院药剂学教研室
【摘要】:目的:制备盐酸哌甲酯缓释微丸,并对其体外释药情况进行研究。方法:采用流化床包衣技术制备盐酸哌甲酯缓释微丸。对包衣材料种类、配比及用量进行选择,建立HPLC法测定包衣微丸体外释放度。HPLC色谱条件:色谱柱:DiamonsilC18(5μm,200 mm×4.6 mm);流动相:甲醇-0.02 mol/L磷酸二氢钾-冰乙酸(40:55:5);检测波长:210 nm;流速:0.8 ml/min;进样量:20μl。结果:乙基纤维素水分散体(Surelease)比丙烯酸树脂水分散体(Eudragit NE30D)更适合作为盐酸哌甲酯缓释微丸的包衣材料。包衣增重15%,HPMC加入量为6%时包衣微丸在不同释放介质(水、pH 1.2盐酸溶液及pH 4.0、pH 6.5p、H 6.8、pH 7.5磷酸盐缓冲溶液)中均呈现良好的缓释效果。结论:成功地制备了盐酸哌甲酯缓释微丸,其体外释药缓慢、持续、平稳。
【关键词】: 盐酸哌甲酯 迟效制剂 缓释微丸 乙基纤维素水分散体 丙烯酸树脂水分散体
会飞的猪猪
第4楼2012/12/15
206.5 HPLC-ELSD法测定天冬总呋甾皂苷中AR-Ⅰ的含量
徐从立 陈海生 谭兴起 宣伟东 梁爽
【作者单位】: 第二军医大学药学院天然药物化学教研室
【摘要】:目的:测定天冬总呋甾皂苷中AR-Ⅰ的含量。方法:采用高效液相色谱法,色谱条件:Diamonsil C18(5 mm×250mm,5μm)色谱柱;流动相:CH3CN-H2O(36∶64);流速:0.8 ml.min-1;进样量20μl;柱温:室温。以ELSD为检测器,气化温度40℃,气体(N2)压力2.0×105Pa。结果:AR-Ⅰ在0.094~0.940 0 g.L-1范围内呈良好线性关系(r=0.999 2),检测具有较高的灵敏度和稳定性,平均回收率为101.3%(n=6),RSD=2.36%。结论:HPLC-ELSD为天冬呋甾皂苷的测定提供了简便实用的分析方法。
【关键词】: 天冬总呋甾皂苷 AR-Ⅰ 色谱法 高效液相
会飞的猪猪
第5楼2012/12/15
206.6 避蚊胺乙基纤维素微球的制备及其性质考察
高静 管斐 高申
【作者单位】: 第二军医大学药学院药剂学教研室; 第二军医大学药学院分析测试中心
【摘要】:目的 :制备避蚊胺乙基纤维素微球 ,考察其性质。方法 :采用溶剂挥发法制备避蚊胺乙基纤维素微球。将乙基纤维素溶于二氯甲烷中 ,滴入避蚊胺 ,密闭超声溶解 ,作为分散相。配制 1%聚乙烯醇水溶液作为连续相。 10 0 0 r/ min搅拌下将分散相缓缓加入连续相中 ,30 min后降低搅速至 6 0 0 r/ min继续搅拌直至二氯甲烷挥干。离心 ,蒸馏水洗 ,冷冻干燥 12 h即得 ,并用扫描电镜观察微球外观 ,光学显微镜下计数 5 0 0个微球考察粒径分布 ,HPL C法 (Diam onsil ODS柱 15 0 mm× 4 .6 mm,流动相为甲醇∶水 =6 5∶ 35 ,检测波长 2 10 nm,流速 1m l/ min) ,建立标准回归方程测定载药量和药物包封率。 结果 :所得微球为乳白色微粒 ,外观圆整 ,粒径 90 %分布在 30~ 70 μm范围内 ,平均算术径 (dar)及平均球径 (dv)分别为 4 9.6 μm和 5 1.2 μm,微球载药量为 18.7% ,包封率可达 5 6 .1% (n=6 )。 结论 :该成球方法简便易行。
【关键词】: 避蚊胺 微球 乙基纤维素 溶剂挥发法
会飞的猪猪
第6楼2012/12/15
206.7 RP-HPLC法测定跌打七厘散中血竭素的含量
张小梅 王宾豪 励娜 梁旭明 杨荣平
【作者单位】: 重庆市中药研究院;
【摘要】:目的:建立RP-HPLC法测定跌打七厘散的含量测定方法。方法:RP-HPLC法,色谱柱为Diamonsil ODS(250 mm×4.6 mm,5μ);流动相:乙腈-0.05 mol/L磷酸二氢钠溶液(45∶55);检测波长:440 nm;柱温:40℃;流速:1 mL/min。结果:血竭素高氯酸盐在0.0476~0.5955μg范围内线性关系良好(r=0.9998)。平均回收率为100.6%,RSD=2.31%。结论:RP-HPLC法简便,快速,准确,可用于跌打七厘散的含量测定。
【关键词】: RP-HPLC 跌打七厘散 血竭素 含量
会飞的猪猪
第7楼2012/12/15
206.8 高效液相色谱法测定川芎中孕烯醇酮的含量
谢秀琼 杨丽红 万丽 王曙宾 张绿明
【作者单位】: 成都中医药大学药学院 成都博瑞医药开发有限公司 成都中医药大学药学院 北京大学药学院 成都中医药大学药学院
【摘要】:目的:建立川芎药材中孕烯醇酮的高效液相色谱法(HPLC)含量测定方法,并对10批川芎药材进行了含量测定。方法:采用HPLC法,色谱柱:Diamomil(r)(钻石)C_(18)(25 cm×4.6 mm,5μm),流动相:乙腈-水(48:2),流速:1 mL/min,测定波长:204nm。结果:孕烯醇酮在0.4016~2.008μg(r=0.9996)范围内,峰面积与进样量呈良好的线性关系;平均加样回收率为98.97%;RSD为1.97%。结论:该方法简便、准确、快速、重复性好,可作为川芎质量评价标准之一。
【关键词】: 川芎 孕烯醇酮 高效液相色谱法测定 含量测定 峰面积 对照品 回收率 流动相 药材 质量评价标准
会飞的猪猪
第8楼2012/12/15
206.9 高效液相色谱法同时测定心迪软胶囊中3种黄酮苷元的含量
王毓杰 张艺 赖先荣 古锐 王平 张祝君
【作者单位】: 成都中医药大学民族医药研究所 成都中医药大学民族医药研究所 成都中医药大学民族医药研究所 成都中医药大学民族医药研究所 成都中医药大学民族医药研究所 四川美大康药业股份有限公司
【摘要】:目的建立心迪软胶囊的质量标准。方法采用高效液相色谱法对心迪软胶囊中的槲皮素、山柰素和异鼠李素同时进行含量测定:Diamonsil(钻石)C18(250 mm×4.6 mm,5μm),乙腈—水—磷酸(30∶70∶0.1)为流动相,流速1 mL/min,检测波长370 nm,柱温40℃。结果槲皮素在0.4118~1.6475μg的范围内线性关系良好,r=0.9998,平均回收率为96.81%,RSD为0.92%(n=6);山柰素在0.0208~0.0832μg的范围内线性关系良好,r=0.9998,平均回收率为96.92%,RSD为2.02%(n=6);异鼠李素在0.1829~0.7316μg的范围内线性关系良好,r=0.9999,平均回收率为97.06%,RSD为1.63%(n=6)。结论高效液相色谱法简便、灵敏、准确,能有效地控制心迪软胶囊的质量。
【关键词】: 心迪软胶囊 槲皮素 山柰素 异鼠李素 高效液相色谱法
会飞的猪猪
第9楼2012/12/15
206.10 四物汤不同提取工艺HPLC指纹图谱研究
何瑶 傅舒 傅超美 游宇 毛茜
【作者单位】: 成都中医药大学药学院;澳门大学中华医药研究院;
【摘要】:采用HPLC指纹图谱研究四物汤不同提取工艺对方中化学成分变化的影响.色谱柱为Dikma Diamon-silTMC18(250 mm×4.6 mm,5μm),流动相为甲醇-0.2%磷酸,梯度洗脱,流速1.0 mL/min,柱温35℃,检测波长280 nm,最后采用2004A版中药色谱指纹图谱相似度评价系统分析.分别建立了四物汤水提、水提醇沉、50%醇提3种提取工艺样品的指纹图谱,并找出了3种样品色谱共有峰的差异.实验结果表明:所建立方法简单,重复性好,为四物汤制剂工艺研究和质量控制的科学、全面评价奠定了基础.
【关键词】: 四物汤 提取工艺 HPLC法 指纹图谱
