wuzidun
第2楼2013/11/06
IFRA的这个上面有写明
Version 3
September 12th, 2007
INTERNATIONAL FRAGRANCE ASSOCIATION
ANALYTICAL PROCEDURE
1. Amyl Cinnamal
CAS: 122-40-7
CAS name: Heptanal, 2-(phenylmethylene)-
Both the (E) and (Z) isomers. .
2. Benzyl Alcohol
CAS: 100-51-6
CAS name: Benzenemethanol
Only one substance is described by this nomenclature.
3. Cinnamyl Alcohol
CAS: 104-54-1
CAS name: 2-Propen-1-ol, 3-phenyl-
Both (E)- and (Z)- isomers are included in our analysis.
4. Citral
CAS: 5392-40-5
CAS name: 2,6-Octadienal, 3,7-dimethyl-
Both (Z)- (Neral: CAS 106-26-3) and (E)- (Geranial: CAS 141-27-5) isomers are
included.
5. Hydroxycitronellal
CAS: 107-75-5
CAS name: Octanal, 7-hydroxy-3,7-dimethyl-
Both (R)- and (S)- enantiomers are included.
International Fragrance Association September 12th, 2007 3/12
6. Eugenol
CAS: 97-53-0
CAS name: Phenol, 2-methoxy-4-(2-propenyl)-
Only one substance described by this nomenclature.
7. Isoeugenol
CAS: 97-54-1
CAS name: Phenol, 2-methoxy-4-(1-propenyl)-
Both (E)- and (Z)- isomers are included.
8. Amylcinnamyl Alcohol
CAS: 101-85-9
CAS name: 1-Heptanol, 2-(phenylmethylene)-
9. Benzyl Salicylate
CAS: 118-58-1
CAS name: Benzoic acid, 2-hydroxy-, phenylmethyl ester
10. Cinnamal
CAS: 104-55-2
CAS name: 2-Propenal, 3-phenyl-
Both (E)- (trans- CAS 14371-10-9) and (Z)- (cis- CAS 57194-69-1) isomers are
included.
11. Coumarin
CAS: 91-64-5
CAS name: 2H-1-Benzopyran-2-one
12. Geraniol
CAS: 106-24-1
CAS name: 2,6-Octadien-1-ol, 3,7-dimethyl-, (E)-
Only one substance described by this nomenclature. The (Z)- isomer (Nerol: CAS
106-25-2) is not included.
International Fragrance Association September 12th, 2007 4/12
13. Hydroxyisohexyl- 3-cyclohexene carboxaldehyde
Trade name : Lyral
CAS: 31906-04-4
CAS name: 3-Cyclohexene-1-carboxaldehyde, 4-(4-hydroxy-4-methylpentyl)-
Only this isomer is included in our analysis although some commercial qualities of this
substance usually contain lesser quantities of the 3-Cyclohexene-1-
carboxaldehyde, 3-(4-hydroxy-4-methylpentyl)- isomer.
14. Anise Alcohol
CAS: 105-13-5
CAS name: Benzenemethanol, 4-methoxy-
15. Benzyl Cinnamate
CAS: 103-41-3
CAS name: 2-Propenoic acid, 3-phenyl-, phenylmethyl ester
Both (E)- and (Z)- cinnamate isomers are included.
16. Farnesol
CAS: 4602-84-0
CAS name: 2,6,10-Dodecatrien-1-ol, 3,7,11-trimethyl-
Undefined mixture of four isomers (predominantly the (E,E) ("trans, trans-Farnesol": CAS
106-28-5) and (Z,E) ("trans, cis-Farnesol": CAS 3790-71-4) .
17. Butylphenyl Methylpropional
Trade name: Lilial
CAS: 80-54-6
CAS name: Benzenepropanal, 4-(1,1-dimethylethyl)-.alpha.-methyl-
Both (R)- and (S)- enantiomers are included in our analysis. The isomeric 2-(3-tert-
Butylbenzyl) propionaldehyde is not included.
18. Linalool
CAS: 78-70-6
CAS name: 1,6-Octadien-3-ol, 3,7-dimethyl-
Both (R)- (CAS # 126-91-0) and (S)- (CAS # 126-90-9) enantiomers are included.
19. Benzyl Benzoate
CAS: 120-51-4
CAS name: Benzoic acid, phenylmethyl ester
International Fragrance Association September 12th, 2007 5/12
20. Citronellol
CAS: 106-22-9
CAS name: 6-Octen-1-ol, 3,7-dimethyl-
Both (R)- ((-): CAS 1117-61-9 )and (S)- ((+): CAS 7540-51-4) enantiomers are
included.
21. Hexyl Cinnamal
CAS: 101-86-0
CAS name: Octanal, 2-(phenylmethylene)-
22. Limonene
CAS: 5989-27-5
CAS name: Cyclohexene, 1-methyl-4-(1-methylethenyl)-, (R)-
Both (R)- and (S)- (CAS # 5989- 54-8) enantiomers may have to be taken into
account . (See special note on LIMONENE).
23. Methyl 2-Octynoate
CAS: 111-12-6
CAS name: 2-Octynoic acid, methyl ester
24. Alpha-Isomethyl Ionone
CAS: 127-51-5
CAS name: 3-Buten-2-one, 3-methyl-4-(2,6,6-trimethyl-2-cyclohexen-1-yl)-
Both (E)- and (Z)- isomers of the specified structural isomer are included in the analysis.
Even though other structural isomers are often present in commercial quantities of this
substance, they are not included.
另外两个是Tree moss extract和Oak moss extract
wuzidun
第4楼2013/11/06
有没有这个资料可以分享啊?CEN Standard 16274:2012
symmacros
第5楼2013/11/06
这些都还是日化香精常用的原料之一。
