GC-MS法测定蔬菜和水果中有机磷和有机氯农药的残留量
Abstract: A method has been developed for the determination of16 organophosphorus and 13 organochlorine pesticides residue in vegetables and fruits by GC-MS 6800 of Skyray Instrument. The samples were extracted with acetonitrile, purified by ENVI-Carb/PSA solid phase extraction cartridge, and analyzed using GC-MS. The method detecion limits of these compounds are in the range from 1.5ug/kg to8.9μg / kg.The method demonstrated high speed, recovery and accuracy on pesticides residue, indicating that GC-MS 6800 can be used to analyze organphosphorus and organochlorine pesticides residue in vegetables and fruits.
图2 13种有机氯标准溶液TIC图
1.α–六六六;2.β–六六六;3.γ–六六六;4.七氯;5.艾氏剂;6.环氧七氯B;7.4,4’-滴滴伊;8.狄氏剂;9. 2,4’-滴滴滴;10.异狄氏剂;11. 4,4’-滴滴滴;
12. 2,4’-滴滴涕;13. 4,4’-滴滴涕
表1 有机磷和有机氯农药重复性测试数据
物质名称 | 峰面积 | RSD% | |||||
1 | 2 | 3 | 4 | 5 | |||
有机磷农药 | 敌敌畏 | 45622 | 45834 | 46092 | 46982 | 46812 | 1.3 |
二嗪磷 | 61574 | 61837 | 62238 | 63018 | 62479 | 0.9 | |
地虫磷 | 70737 | 71142 | 71634 | 72143 | 71810 | 0.8 | |
甲基毒死蜱 | 29882 | 30172 | 30563 | 31154 | 30761 | 1.6 | |
甲基对硫磷 | 11343 | 11514 | 11748 | 12015 | 11853 | 2.3 | |
甲基嘧啶磷 | 35332 | 35840 | 36465 | 37111 | 36714 | 2.0 | |
杀螟硫磷 | 14183 | 14212 | 14435 | 15046 | 14612 | 2.4 | |
马拉硫磷 | 15704 | 15923 | 16111 | 16425 | 16343 | 1.8 | |
毒死蜱 | 21274 | 21574 | 21778 | 22149 | 21942 | 1.5 | |
对硫磷 | 8782 | 8844 | 8974 | 9272 | 9114 | 2.2 | |
毒虫威 | 24020 | 24467 | 25067 | 26145 | 25340 | 3.3 | |
杀扑磷 | 35837 | 36531 | 37239 | 38105 | 37472 | 2.4 | |
乙硫磷 | 118422 | 121634 | 125662 | 129021 | 126424 | 3.4 | |
三硫磷 | 91214 | 91842 | 92945 | 97543 | 94122 | 2.7 | |
伏杀磷 | 80354 | 81457 | 82159 | 84024 | 82743 | 1.7 | |
甲基谷硫磷 | 45832 | 46131 | 46934 | 48037 | 47152 | 1.9 | |
有机氯农药 | α–六六六 | 83387 | 84158 | 82180 | 84076 | 85021 | 1.3 |
β–六六六 | 108527 | 112521 | 110537 | 109521 | 107471 | 1.8 | |
γ–六六六 | 87658 | 88759 | 86160 | 88061 | 89762 | 1.5 | |
七氯 | 78479 | 78050 | 77438 | 79289 | 79643 | 1.1 | |
艾氏剂 | 147887 | 155828 | 150871 | 149890 | 154231 | 2.1 | |
环氧七氯B | 204640 | 213641 | 207672 | 202643 | 208630 | 2.0 | |
4,4’-滴滴伊 | 966375 | 988341 | 967323 | 972379 | 973332 | 0.9 | |
狄氏剂 | 934799 | 941790 | 931791 | 940791 | 948799 | 0.7 | |
2,4’-滴滴滴 | 2050314 | 2090317 | 2020312 | 2070398 | 2001324 | 1.8 | |
异狄氏剂 | 1815158 | 1875137 | 1849179 | 1867789 | 1881539 | 1.4 | |
4,4’-滴滴滴 | 1657734 | 1660431 | 1647749 | 1627759 | 1680238 | 1.2 | |
2,4’-滴滴涕 | 3328059 | 3543165 | 3488061 | 3508041 | 3574563 | 2.7 | |
4,4’-滴滴涕 | 3527504 | 3745273 | 3799270 | 3621085 | 3757150 | 3.1 |
表2 实际样品测试结果(单位:ug/kg)
有机磷农药 | 样品名称 | 方法检出限 | 有机氯农药 | 样品名称 | 方法检出限 | ||
黄瓜 | 水蜜桃 | 黄瓜 | 水蜜桃 | ||||
敌敌畏 | 8.7 | 13.3 | 2.8 | α –六六六 | - | - | 1.7 |
二嗪磷 | - | - | 2.2 | β–六六六 | - | - | 1.5 |
地虫磷 | - | - | 1.9 | γ–六六六 | - | - | 1.7 |
甲基毒死蜱 | - | - | 3.1 | 七氯 | - | - | 2.3 |
甲基对硫磷 | - | - | 5.3 | 艾氏剂 | - | - | 2.1 |
甲基嘧啶磷 | 16.9 | 25.3 | 4.2 | 环氧七氯B | - | - | 2.6 |
杀螟硫磷 | - | - | 4.8 | 4,4’-滴滴伊 | - | - | 3.3 |
马拉硫磷 | - | - | 5.9 | 狄氏剂 | - | - | 7.7 |
毒死蜱 | 11.2 | - | 5.5 | 2,4’-滴滴滴 | - | 21.6 | 4.2 |
对硫磷 | - | - | 6.3 | 异狄氏剂 | - | - | 3.8 |
毒虫威 | - | - | 5.5 | 4,4’-滴滴滴 | - | 18.2 | 4.5 |
杀扑磷 | - | - | 4.9 | 2,4’-滴滴涕 | - | - | 4.5 |
乙硫磷 | - | - | 4.2 | 4,4’-滴滴涕 | - | - | 4.5 |
三硫磷 | - | - | 5.7 | ||||
伏杀磷 | - | - | 7.6 | ||||
甲基谷硫磷 | - | - | 8.9 |
