EN 13432&ASTM D6400&ASTM D6868产品测试及认证 可降解物质/产品测试认证-可降解标志 可降解产品认证相关标准: -DIN V 54900,“Testing of the compostability of plastics”(replaced by DIN EN 13432) -EN 13432"Packaging-Requirements for packaging recoverable through composting and biodegradation-Test scheme and evaluation criteria for the final acceptance of packaging" -ASTM D6400 "Standard Specification for Compostable Plastics" -ASTM D6868 “Standard Specification for Labeling of End Items that Incorporate Plastics and Polymers as Coatings or Additives with Paper and Other Substrates Designed to be Aerobically Composted in Municipal or Industrial Facilities” - ASTM D6866 ” Standard Test Methods for Determining the Biobased Content of Solid, Liquid, and Gaseous Samples Using Radiocarbon Analysis” 可降解标志可以证明您的产品与众不同-EN 13432测试及认证 -无论是包装袋、购物袋、垃圾袋,还是餐具,环保是大势所趋。产品使用可生物降解的塑料或其他物质制作可符合生态要求。 -可降解标志的透明性可以帮助买家很容易鉴别合适的供应商喝制造商,您的客户也需要一个可靠的引导来帮助他作出决定是否购买使用,可降解标志就可以做到这一点。 -可降解标志是一个质量标志,可以证明您的产品已经通过了权威专业的独立第三方透明地测试和评估,符合相关要求,可在市场上自由销售。
