原子吸收测定钆的含量
原子吸收光谱(AAS)
  • 我公司有一个药品要出口,需用原子吸收测定钆的含量,我们公司的原子吸收目前不具备检测能力,如有检测能力,请联系我商谈检测费用事宜。具体方法如下:
    Assay of gadolinium.
    Limit:
    1 ml of the product should have 74.6 - 82.4 mg (95-105%) of gadolinium.
    The assay is performed by atom absorption spectroscopy.
    Reagents:
    65% (w/w) nitric acid, Suprapur (Merck) or similar;
    30% (w/w) hydrochloric acid, Suprapur (Merck) or similar;
    Water with ≤50 µS conductivity;
    10% (w/v) cesium chloride
    Dissolve 10.00 g of cesium chloride Suprapur (Merck) in water with ≤50 µS conductivity contained in 100 ml volumetric flask and dilute to volume with the same solvent;
    Gadolinium (III) oxide solution working standard; 10000 mg Gd per liter
    Methods:
    Preparation of test solution:
    Expose 1.00 ml of product (v) in porcelain pot to 0.2 ml of 65% (w/w) nitric acid, evaporate on a hot stove, dry, ignite at approximately 500°C, then burn in muffle furnace at 800°C till black particles disappear (approximately 1 hour). Then leave the residue to cool to room temperature on fire-resistant surface. Dissolve the white residue at heating in 1.0 ml of water and 1.0 ml of 30% (w/w) hydrochloric acid, Suprapur (Merck) or similar. Put the solution quantitatively to 100 ml volumetric flask, add 10 ml of 10% (w/v) cesium chloride solution, dilute to volume with water with ≤50 µS conductivity.
    Preparation of gadolinium stock standard solution:
    Dissolve the weighting of 11.5260 g of gadolinium (III) oxide working standard (accurately weighted) (MR) in 25 ml of 30% (w/w) hydrochloric acid Suprapur (Merck) or similar in 1000 ml volumetric flask, then dilute to volume with water with ≤50 µS conductivity (C=~10 mg of gadolinium per ml).
    Preparation of gadolinium standard solutions 1, 2 and 3:
    Put 3.0 ml, 4.0 ml and 5.0 ml of gadolinium stock standard solution into individual 50 ml volumetric flasks, add 5.0 ml of 10% (w/v) cesium chloride solution and 0.5 ml of 30% (w/w) of hydrochloric acid, Suprapur (Merck) or similar, then dilute to volume with water with ≤50 µS conductivity (corresponds to 600 mg of gadolinium per liter, 800 mg gadolinium per liter and 1000 mg of gadolinium per liter respectively).
    Control test:
    Put 10.0 ml of 10% (w/v) cesium chloride solution into 100 ml volumetric flask, add 1.0 ml of 30% (w/w) hydrochloric acid, Suprapur (Merck) or similar and then dilute to volume with water ≤50 µS with conductivity.
    Chromatographic conditions:
    Device
    Atomic absorption flame spectrophotometer
    Measurement type
    Absorption with background compensation
    Light source
    Gadolinium hollow cathode lamp
    Conditioning time
    15 minutes
    Measured wavelength
    368.4 nm
    Opening width
    0.2 nm
    Fuel gas
    Acetylene > 99.6% (v/v) free from solvent
    Oxidant
    Nitrous oxide >99.8% (v/v)
    Burner type
    Nitrous oxide burner
    Calibration method
    Linear
    Methods:
    Perform three quantifications of test solution and standard solutions 1, 2 and 3. Use average value of three quantifications for the calculation.
  • 该帖子已被版主-冰山加2积分,加2经验;加分理由:话题
  • 冰山
    第1楼2013/09/12
    这项目还是做过的老手做吧!要是从头开始购买灯、标液及一氧化二氮等材料物品,并建立测定方法,验证试验等等,得花上万块吧!
  • wmj31
    第2楼2013/09/12
    比较好奇的是什么类型的药品,钆好高的浓度啊。这个方法中钆的标准溶液的浓度为0.6,0.8,1.0mg/ml。好高的浓度。
  • tshwjx
    第4楼2013/09/13
    本药品为磁共振造影剂
  • tshwjx
    第5楼2013/09/13
    帖子内的检测方法系药典方法,不需要做验证
  • 夕阳
    第6楼2013/09/14
    有钆这种阴极灯吗?
  • 冰山
    第7楼2013/09/14
    一般这样不常见的冷僻项目,检测费用是多少?
    估计重赏之下才有勇夫吧?
  • 稻草新希
    第8楼2013/09/25
    没见过 北京那没有这个灯吗,有色金属研究所
