(1) Need (Editor/Reviewer角度想要看到的“文章的意义/贡献”:) . What is the context for the research work? What would we like to be able to do in practice that we don’t know how to do at present?
Prosecution case (Editor/Reviewer角度的质疑): • This research is not important • The problem is too specific and clearly does not lead to transferable knowledge
(2) Analysis of existing work ( 做Introduction部分的文献综述的目的 ). There are two purposes to examining previous work: to summarise previous work in the area (what knowledge exists in the area and is relevant to the need defined above), and to.....
