附件:
我在故我思
第1楼2006/08/13
Method 508
Determination of Chlorinated Pesticides in Water by Gas Chromatography with an Electron Capture Detector - Revision 3.1.
Method 508.1
Determination of Chlorinated Pesticides, Herbicides, and Organohalides by Liquid-Solid Extraction and Electron Capture Gas Chromatography -Revision 2.0.
Method 508A
Screening for Polychlorinated Biphenyls by Perchlorination and Gas Chromatography - Revision 1.0.
Method 515.1
Determination of Chlorinated Acids in Water by Gas Chromatography with an Electron Capture Detector - Revision 4.1.
Method 515.2
Determination of Chlorinated Acids in Water using Liquid-Solid Extraction and Gas Chromatography with an Electron Capture Detector - Revision 1.1.
EPA-02
我在故我思
第2楼2006/08/13
Method 524.2
Measurement of Purgeable Organic Compounds in Water by Capillary Column Gas Chromatography/Mass Spectrometry - Revision 4.1.
Method 525.1
Determination of Organic Compounds in Drinking Water by Liquids-Solid Extraction and Capillary Column Gas Chromatography/Mass Spectrometry, Revision 2.2.
Method 525.2
Determination of Organic Compounds in Drinking Water by Liquid-Solid Extraction and Capillary Column Gas Chromatography/Mass Spectrometry -Revision 2.0.
Method 531.1
Measurement of N-Methylcarbamoyloximes and N-Methylcarbamates in Water by Direct Aqueous Injection HPLC with Post Column Derivatization -Revision 3.1.
Method 547
Determination of Glyphosate in Drinking Water by Direct-Aqueous-Injection b HPLC, Post-Column Derivatization, and Fluorescence Detection - July 1990.
EPA-03
我在故我思
第3楼2006/08/13
Method 548
Determination of Endothall in Drinking Water by Aqueous Derivatization, Liquid-Solid Extraction, and Gas Chromatography with Electron Capture Detection.
Method 548.1
Determination of Endothall in Drinking Water by Ion Exchange Extraction, c Acidic Methanol Methylation and Gas Chromatography/Mass Spectrometry -Revision 1.0.
Method 549.1
Determination of Diquat and Paraquat in Drinking Water by Liquid-Solid c Extraction and HPLC with Ultraviolet Detection - Revision 1.0.
Method 550
Determination of Polycyclic Aromatic Hydrocarbons in Drinking Water By b Liquid-Liquid Extraction and HPLC with Coupled Ultraviolet and Fluorescence Detection.
Method 550.1
Determination of Polycyclic Aromatic Hydrocarbons in Drinking Water by Liquid-Solid Extraction and HPLC with Coupled Ultraviolet and Fluorescence Detection.
EPA-04
我在故我思
第4楼2006/08/13
Method 551
Determination of Chlorination Disinfection Byproducts and Chlorinated Solvents in Drinking Water by Liquid-Liquid Extraction and Gas Chromatography with Electron Capture Detection.
Method 551.1
Determination of Chlorination Disinfection Byproducts, Chlorinated Solvents, and Halogenated Pesticides/Herbicides in Drinking Water by Liquid-Liquid Extraction and Gas Chromatography with Electron-Capture Detection -Revision 1.0.
Method 552
Determination of Haloacetic Acids in Drinking Water by Liquid-Liquid Extraction, Derivatization, and Gas Chromatography with Electron Capture Detection.
Method 552.1
Determination of Haloacetic Acids and Dalapon in Drinking Water by Ion Exchange Liquid-Solid Extraction and Gas Chromatography with an Electron Capture Detector - Revision 1.0.
EPA-05
我在故我思
第5楼2006/08/13
Method 552.2
Determination of Haloacetic Acids and Dalapon in Drinking Water by Liquid-Liquid Extraction, Derivatization and Gas Chromatography with Electron Capture Detection - Revision 1.0.
Method 553
Determination of Benzidines and Nitrogen-Containing Pesticides in Water by Liquid-Liquid Extraction or Liquid-Solid Extraction and Reverse Phase High Performance Liquid Chromatography/Particle Beam/Mass Spectrometry -Revision 1.1.
Method 554
Determination of Carbonyl Compounds in Drinking Water by Dinitrophenylhydrazine Derivatization and High Performance Liquid Chromatography - Revision 1.0.
Method 555
Determination of Chlorinated Acids in Water by High Performance Liquid Chromatography with a Photodiode Array Ultraviolet Detector - Revision 1.0
EPA-06
