把他们的英文指标当成一篇文章来看,你会发现安捷伦真的是语言大师!!
qdcy 发表:Flow precision ≤0.07 % RSD,or ≤0.02 min SD whatever is greater, based on retention time at constant room temperature
Pressure
Operating range 0 - 40 MPa (0 - 400 bar, 0 - 5880 psi) up to 5 ml/min
0 - 20 MPa (0 - 200 bar, 0 - 2950 psi) up to 10 ml/min
Delay volume 800 - 1100 µL depending on back pressure
Detection type Double-beam photometer
Light source Deuterium lamp
Noise ± 0.75 x 10 -5 AU, at 254 nm
Drift 3 x 10-4AU/hr, at 254 nm
Linearity >2 AU upper limit
Wavelength range 190-600 nm
Maximum data rate 13 Hz
