Spain
第3楼2012/03/23
一般FR其实就已经帮你K-M变换了。
The Kubelka-Munk theory is generally used for the analysis of diffuse reflectance spectra obtained from weakly absorbing samples. It provides a correlation between reflectance and concentration. The concentration of an absorbing species can be determined using the Kubelka Munk formula:
F(R) = (1-R)²/2R = k/s = Ac/s
R = reflectance
k = absorption coefficient
s = scattering coefficient
c = concentration of the absorbing species
A = absorbance
juzi618
第4楼2012/03/25
学习了
p3226105
第5楼2017/04/24
你好, 不是很理解,这里的F(R)代表的是什么,是直接测的反射值吗?那这个反射值是与浓度成比例的吗,谢谢
