冲压课Stamping Section 冲压区Stamping Area 冲压现场办公区Stamping Section Office 点焊区Welding Area 拉钉区Riveting Area 打磨区Sanding Area 拉钉现场办公区Riveting Section Office 废弃物存放区Scrap Area 烤漆课Coating Section 烤漆区Coating Area 液体/粉体Liquid/Powder 烤漆清洗线Degreasing Process 烤漆前处理区Coating Prep Area 超音波清洗区Ultrasonic Cleaning Process 粉体烤漆线Powder Coating Line 液体烤漆线Liquid Painting Line 粉体涂装室Powder Coating Spraying Room 液体涂装室Liquid Painting Spraying Room 烤漆课现场办公区Coating Section Office 集尘室Dust Collector Room 吹尘室Dust Blow Off Room 调漆室Paint Mixing Room 打磨房Sanding Room 煤气房Natural Gas Control Room 预脱脂槽Degreasing Area Stage 1 主脱脂槽Degreasing Area Stage 2 皮膜槽Metal Surface Phosphate Treating Area 清水槽Rinsing Area 沉淀储水池Waste Deposit 小心吊物Warning: Hooks in Operation 小心碰头Warning: Head Injury, Low Shelves 更衣间Dressing Room 闲人免进Warning: Only Authorized Personnel 警告: 须着防静电衣后才可入内. Warning: Antistatic Clothing is Required 贵宾衣柜/鞋柜For Visitors Use Only 员工鞋柜Employee Shoes Lockers 杂项物料区Miscellaneous Items Storage 不合格品区Non-Conforming Parts Area 废弃物存放区Scrap Area 烤漆制具保养室Masking Maintenance 烤漆卸制具制程De-Masking Process 治具保养室Fixture/Jig/Gauge Maintenance 组配课Assembly Section 组配区Assembly Area 上班入口Entrance 下班出口Exit 组配现场办公区Assembly Section Office 包材作业区Packaging Area 备料区Material Staging Area 不合格品区Non-conforming Parts Area 换鞋间Changing Room 为保持清洁,请您换鞋. For cleanliness, please change your shoes. 组装线Assembly Line 负责人Line Leader 前置加工线Prep Line 散件大宗线Accessory Part Assembly Line 会议室Conference Room 洗手间Rest Room 茶水间Tea Room 电脑机房MIS Server Room 复印室Copy Room 教育训练室Training Room 仓管课Warehouse Management Section 品管部QC Dept. 品管部资料室document Control, QC Dept. 品管部样品室QC Sample Room 塑料厂Plastic Plant 塑料厂厂长室Plastic Plant Manager 塑料厂经理室Manager 塑料成型课Molding Section 物料室Raw Material Warehouse/Storage 碎料室Crusher Room 模具存放区Tooling Warehouse 成型课现场办公区Molding Section Office 工具区Accessorial Tools Storage 治具柜放置区Fixture/Jig/Gauge Racks 设备维修区Tooling Maintenance Area 柜式烤炉Oven 不良品放置区Non-Conforming Product Area 重工区Rework Area 包材存放区Packing Material Area 塑料喷漆印刷课Plastic Decoration Section 周转包材放置区Recycled Packaging Materials Rack 大宗包材放置区Packaging Material Rack 待印刷产品放置区Silkscreen/Pad Printing WIP Material 待喷漆产品放置区WIP Material 调漆房&治具房Paint Mixing Room & Fixture Shop 重点防火区No Fire Area 喷漆房Painting Room 谢绝参观Authorized Personnel Only 浴尘室除尘Dust Vacuum Room 1.进门灯显示绿灯时开门进入浴尘室 1. Enter the room when light turns green. 2.将进门关上后自动除尘 2.Close door to start vacuum 3.除尘时间约为8秒,听到"啪"一声后开门走出 3.Vacuum time 8 seconds. Exit room at the sound of the "pop". 塑料厂设计课Plastic Molding Design Section 塑料制模课Tooling Fabrication Section 修模区Tooling Repair Area 省模区Polishing Area 制模区Tooling Fabrication Area EDM加工区EDM Area CNC加工区CNC Area 检验区Inspection Area 外发区Shipping Area 模具厂/中心Tooling Plant/Center 模具厂办公室Tooling Center Office 五金模具厂Sheet Metal Tooling Shop 五金加工设计课Sheet Metal Tooling Design Section 五金模具维修区Sheet Metal Tooling Maintenance Area 五金模具制模区Sheet Metal Tooling Fabrication Area 线割房Wire Cutting Shop 五金工具室Tooling Parts Storage CNC加工区CNC Area 样品室Sample Room 试模区Stamping Try-Out Area 会议室Conference Room 厂长室Plant Manager 铁材仓Sheet Metal Warehouse ----Raw Materials 冲件仓Stamping Warehouse ---- WIP 包材仓Packaging Material Warehouse 塑料仓Injection Molding Warehouse ---- WIP 待验区Holding Area 贵重物品仓High value Materials Warehouse 特殊物料仓Special Item Storage 塑料原料区Plastic Warehouse - Raw Materials 不合格仓Non-conforming Parts Area 烤漆件仓 Coating Parts Warehouse 成品仓Finished Product Warehouse 小件仓Small Parts Warehouse 收料窗口Receiving Window IQC 检验台IQC Inspection Station QA实验室Quality Assurance QA量测室QA Measurement Office 模具仓Tooling Warehouse (来自互联网)
