1 | 7890B Series gc with SSL inlet and interface |
7890B系列气相色谱主机带 分流/不分流进样口及质谱接口 |
2 | 7000C Quadrupole MS/MS EI System |
7000C串联四级杆主机 |
3 | NIST 2014 MS Library Bundle |
NIST 2014 谱库 |
4 | Install Kit for gcs w/out Gas Purifiers, |
起始工具包 |
5 | 7650A Autoinjector |
7650自动进样器,包括一套塔座,50位进样塔 |
6 | 7697A Headspace Sampler, 12 Vial. Single vial heating. Controlled by built-in keypad or external data system. Includes onboard EPC, LAN and APG communication, 1mL sample loop |
12位顶空自动进样器 |
消耗品 |
8 | Liner O-Ring, Non-Stick 10PK |
衬管非粘连O圈 10/PK |
9 | Agilent Advanced Green 11mm septa, 50/pk |
进样口高级绿色隔垫 50/pk |
10 | Liner,UI,splitless,sngle taper,glasswool |
超惰性预装填玻璃棉衬管 |
11 | Screw top vial, 2mL, clear wide opening 100/pk |
样品瓶.100个/包 |
12 | Blue screw cap, PTFE/red silicone rubber septa 100/pk 盖子 |
2ml 进样瓶盖及垫 |
13 | Ferrule, 0.4mm VG 0.1-0.25 col 10/PK |
质谱端石墨垫 |
14 | Vacuum pump fluid |
真空泵油 |
15 | Filament assembly |
灯丝 |
16 | Big Universal Trap, 1/8" fttgs, Helium |
氦气捕集阱 |
17 | Syringe, 10ul tapered, FN 23-26s/42/HP |
10ul进样针 |
