仪器运行正常,变色龙突然提示: 9:12:39 {EluentGenerator} Module did not respond in a timely manner. Please check that your USB cables are securely connected and that the module and any USB hubs are powered on. 没有出现过这样的情况,大家有吗? 个人推测是电脑主板usb的问题。 解决当然是更换了插口然后重启系统,但是没有找到真因。 各位分享下
