超级好的东东!
小不董(doxw0323) 发表:http://www.instrument.com.cn/show/download/shtml/033275.shtml
刚上传的,现在好象不能设置0分下载了,就设了1分,Agilent GPC Data Analysis Software for Agilent ChemStation Installing and Understanding
不知道大家觉得有帮助不,是英文的。Contents
1 Installing the GPC Data Analysis Software 11
Minimum Requirements for the Agilent GPC Data Analysis Software (32bit
version) 12
Operating System 12
Minimum PC Configuration 12
Printers for the Agilent GPC Data Analysis Software 13
Installing the Agilent GPC Data Analysis Software 14
Installation Verification 15
Uninstalling the Agilent GPC Data Analysis Software 17
Maintaining the Agilent GPC Data Analysis Software 18
2 Basic Theory of GPC 19
Basics of Gel Permeation Chromatography 20
Molecular Weight Averages and Mass distributions 21
Calibration 23
Calibration with Polymer Standards of Narrow Mass distribution 23
Calibration using Universal Calibration 23
Calibration with Broad Standards 25
Flow Correction and Internal Standard 27
Determination of Detector Delay 30
Separation Efficiency, Resolution and Plate Count 31
3 Introduction to the GPC Data Analysis Software 33
Overview 34
Preparation for GPC Data Processing 36
Start Manual Data Processing 37
Create a New Narrow Standard Calibration Curve 38
Quality of the Calibration Curve 40
Automated Analysis of an Unknown Sample with the New Calibration 42
Comparing Existing Data Files—Overlays 43
Recalibrating an Existing Calibration Curve with Existing Data Files 44
Recalibrating an Existing Calibration Curve with a New Sequence 46
Comparing Original and Recalibrated Calibration Curve 48
Using System Verification 49
4 Interactions Between Agilent ChemStation and the Agilent GPC Data Analysis
Software 51
Interactive Data Analysis From the Agilent ChemStation Data Analysis View 52
Optimization of the Integration Parameters 57
With the ChemStation Integrator 57
With Fixed Settings 59
Automated Data Analysis 60
Automated GPC Recalibration 61
5 Software Windows and Menus 63
Description of Menus 64
The Window Menu 66
Raw Data Window 68
Window Description and Options 68
Functions of the X-axis 70
Menu Raw Data 71
Menu Calibration Data 72
Menu Editor 73
Menu Options 74
Elugram Window 75
Window Description and Options 75
Functions of the X-axis 76
Menu File 77
Menu Overlay 77
Menu Curves 79
Menu Options 81
Overlay Mode 82
Mass Distribution Window 83
File 85
Options 85
The Calibration Window 87
General Description 88
Menu Structure of Calibration Window 89
Data Editor Section 91
Graphical Window Section 92
Creating a Narrow Standard Calibration Curve 93
Creating a Universal Calibration Curve 96
Creating a Broad Standard Calibration Curve 96
Creating an Integral Calibration Curve 100
6 Appendix 103
Relation between Curve Color and Line Style in Monochrome Printing 104
System Verification 105
Experimental Conditions 105
Theoretical Results 105
Default Settings 106
Default Calibration File (def.cal) 106
Default Acquisition Parameters 106
