回头无涯
第2楼2016/11/22
可以看看2015/863/EU原文中。
Substitutes that have less negative impacts are available for DEHP, BBP, DBP and DIBP in most EEE. The use of those substances in EEE should therefore be restricted. DEHP, BBP and DBP are already restricted through entry 51 of Annex XVII to Regulation (EC) No 1907/2006 of the European Parliament and of the Council, (2) so that toys containing DEHP, BBP or DBP in a concentration greater than 0,1 % by weight of the plasticised material, calculated for the three phthalates cumulatively, cannot be placed on the EU market. In order to avoid double regulation, the restriction through entry 51 of Annex XVII to that Regulation shall therefore continue to be the only restriction applicable to DEHP, BBP and DBP in toys.
依风1986
第3楼2016/11/22
感谢老师解释,我们一些客户的产品如电动玩具枪,一般12岁以上,看到外部报告走欧盟(不含特定国家)的话,测试项目主要是REACH Regulation (EC) no. 1907/2006, Annex XVII Items 51 & 52 & amendment no.
552/2009
- Phthalates content,EN71-3 :2013 for selected heavy metals,REACH Regulation (EC) No.1907/2006 , Annex XVII Item 23 & amendment No. 2016/217
- Cadmium content requirement,94/62/EC and amendment 2013/2/EU & Directive (EU) 2015/720 Directive (packaging waste)
- Toxic elements test,
