第1楼2004/07/25
请联系:
tanglin@sinoinstrument.com
我提供给您一份AP-100自动旋光测定仪说明书供您参考。
ATAGO的产品,东南科仪总代理。
Measurement readings
测定参数 Angle of Rotation°
International Sugar Scale(ATC), International Sugar Scale (ATC)
Specific Optical Rotation°, Concentration, and Purity.
旋光度°;国际糖度单位Z°; 比旋度°;(蔗糖溶液)浓度;(糖)纯度。
Measurement range
测定范围 Angle of Rotation:-89.99 to +89.99o International Sugar Scale:-130.00 to +130.00oZ
旋光度测定范围: 国际糖度范围:
Minimum indication
读数刻度(精度) Angle of Rotation:0.01o International Sugar Scale: 0.03oZ
(Checked by reading a standard quarts plate)
Input power supply AC100 to 240V, 50/60Hz 全球适应电压设计
Size and weight 48.5 x 28.5 x 17.5cm, 11.5kg
