请问540是几位有效数字。根据国际上的一些资料 它是2位有效数字。只有后面加小数点才是3位有效数字。 5. Trailing zeros in a whole number with the decimal shown ARE significant. Placing a decimal at the end of a number is usually not done. By convention, however, this decimal indicates a significant zero. For example, "540." indicates that the trailing zero IS significant; there are THREE significant figures in this value. 6. Trailing zeros in a whole number with no decimal shown are NOT significant. Writing just "540" indicates that the zero is NOT significant, and there are only TWO significant figures in this value.
