电位滴定法测定脱硫滤渣中亚硫酸盐
王海州,王海旭,沙建亭
图1 电位滴定过程
Figure 1 Process of potentiometric titration
表1 准确度结果
Table 1 Results of accuracy
样品称取量/g | 硫代硫酸钠消耗体积/mL | 亚硫酸钠含量/% | 回收率/% |
0.1189 | 7.3901 | 93.99 | 96.90 |
0.1348 | 4.9786 | 94.25 | 97.17 |
0.1321 | 5.358 | 94.36 | 97.28 |
0.1536 | 2.2371 | 94.05 | 96.96 |
0.1331 | 5.2569 | 94.14 | 97.05 |
0.1306 | 5.0692 | 93.94 | 96.85 |
0.1186 | 7.4428 | 94.16 | 97.07 |
表2 取样随机性对测定结果的影响
Table2 The influence of sampling randomness on the determinationresults
样品称取量/g | 硫代硫酸钠消耗体积/mL | 测得亚硫酸镁含量/% |
0.1993 | 7.3676 | 33.46 |
0.2491 | 3.7306 | 34.17 |
0.1972 | 8.128 | 31.86 |
0.3079 | 1.5763 | 31.18 |
0.2891 | 1.3914 | 33.54 |
0.2856 | 0.6801 | 35.21 |
0.2714 | 1.407 | 35.69 |
表3 多点取样测定结果
Table 3 Results of mutipointsampling
样品空干基称取量/g | 硫代硫酸钠消耗体积/mL | 测得空干基亚硫酸镁含量/% | 样品含水率 | 样品亚硫酸镁含量/% |
0.2102 | 2.6751 | 44.33 | 26.10% | 32.76 |
0.2053 | 3.175 | 44.12 | 32.60 | |
0.2032 | 3.3712 | 44.07 | 32.56 | |
0.1878 | 4.6347 | 44.15 | 32.63 | |
0.2012 | 3.5288 | 44.09 | 32.58 | |
0.2191 | 1.8648 | 44.47 | 32.87 | |
0.2352 | 0.6269 | 44.19 | 32.65 |
表4 样品有效性试验结果
Table4 Results of sample validity
放置日期 | 样品称取量/g | 硫代硫酸钠消耗体积/mL | 样品亚硫酸镁含量/% |
0天 | 0.2162 | 7.1148 | 32.34 |
1天 | 0.2053 | 10.116 | 26.39 |
2天 | 0.3532 | 4.8021 | 23.23 |
3天 | 0.3554 | 8.5039 | 17.62 |
4天 | 0.2516 | 14.8379 | 11.69 |
表5 真空干燥处理后放置不同时间的测定结果
Table 5 The determination resultsof different time after vacuum drying
放置日期 | 样品空干基称取量/g | 硫代硫酸钠消耗体积/mL | 测得空干基亚硫酸镁含量/% | 样品含水率 | 样品亚硫酸镁含量/% |
0天 | 0.2102 | 2.6751 | 44.33 | 26.10% | 32.76 |
1天 | 0.2012 | 3.5288 | 44.09 | 32.58 | |
2天 | 0.2213 | 1.9183 | 43.90 | 32.44 | |
3天 | 0.1879 | 4.6622 | 44.05 | 32.55 | |
4天 | 0.2204 | 2.0595 | 43.74 | 32.33 |
Torii, Mel al. Operationresults IHI flue gas desulfurization system for coal-fired boiler of IPP .IHI Eng Rev, 2001, 34 (4): 114-117.
Koehler G R. Alkaline scrubbingremoves sulfur dioxide . Chemical Engineering progress, 1974, 70 (6): 63-65.
Hirofumi Kikkawa,Takanori Nakamoto,Masanori Morishita,et al.New Wet FGD Process Using GranularLimestone . Industrial and Engineering Chemistry Resarch,2002,41 (12): 3028-3036.
刘方斌. 首个利用脱硫回收硫酸镁项目获成功 . 中国化工报,2009-08-10 (7).
郭如新. 镁法烟气脱硫联产硫酸镁肥料 . 磷肥与复肥,2010,25 (1), 53-55.
王金霞,林江丽,鹿毅,等. 荧光衍生化法测定新疆特色葡萄干中总亚硫酸盐含量 . 食品科学,2016, 37 (4), 212-215.
宋玉国,申玉华. 离子色谱法测定苦碟子注射液中硫酸盐和亚硫酸盐 . 药物分析杂志, 2012, 32 (5), 857-860.
杨文英,王芳. 甲醛吸收-盐酸副玫瑰苯胺法测定食品中的亚硫酸盐 . 中国卫生检验杂志, 2006, 16 (4), 400-402.
游京晶 ,李冬梅 ,戚苓 ,等. 电位滴定法测定食品中的亚硫酸盐 . 食品与发酵工业, 1992, 18 (3), 60-66+80.
