1. Based on TEM studies add Pd particle size distributions to the results. 2. From the PSD calculate the surface-average particle size of Pd and calculate TOF values to compare in a more advanced way the catalyst performance. 3. Reaction rate (mol converted h-1 mol Pd-1) 如上3个问题:
