【分享】模具工程常用词汇中英文对照
专业英语
  • die 模具
    figure file, chart file图档
    cutting die, blanking die冲裁模
    progressive die, follow (-on)die 连续模
    compound die复合模
    punched hole冲孔
    panel board镶块
    to cutedges=side cut=side scrap切边
    to bending折弯
    to pull, to stretch拉伸
    Line streching, line pulling线拉伸
    engraving, to engrave刻印
    upsiding down edges翻边
    to stake铆合
    designing, to design设计
    design modification设计变化
    die block模块
    folded block折弯块
    sliding block滑块
    location pin定位销
    lifting pin顶料销
    die plate, front board模板
    padding block垫块
    stepping bar垫条
    upper die base上模座
    lower die base下模座
    upper supporting blank上承板
    upper padding plate blank上垫板
    spare dies模具备品
    spring 弹簧
    bolt螺栓
    document folder文件夹
    file folder资料夹
    to put file in order整理资料
    spare tools location手工备品仓
    first count初盘人
    first check初盘复棹人
    second count 复盘人
    second check复盘复核人
    equipment设备
    waste materials废料
    work in progress product在制品
    casing = containerazation装箱
    quantity of physical invetory second count 复盘点数量
    quantity of customs count 会计师盘,点数量
    the first page第一联
    filed by accounting department for reference会计部存查
    end-user/using unit(department)使用单位
    summary of year-end physical inventory bills 年终盘点截止单据汇总表
    bill name单据名称
    This sheet and physical inventory list will be sent to accounting department together (Those of NHK will be sent to financial department)
    本表请与盘点清册一起送会计部-(NHK厂区送财会部)
    Application status records of year-end physical inventory List and physical inventory card 年终盘点卡与清册使用-状况明细表
    blank and waste sheet NO. 空白与作废单号
    plate电镀
    mold成型
    material for engineering mold testing工程试模材料
    not included in physical inventory不列入盘点
    sample样品
    incoming material to be inspected进货待验
    description品名
    steel/rolled steel钢材
    material statistics sheet 物料统计明细表
    meeting minutes会议记录
    meeting type 会别
    distribution department分发单位
    location地点
    chairman主席
    present members出席人员
    subject主题
    conclusion结论
    decision items决议事项
    responsible department负责单位
    pre-fixed finishing date预定完成日
    approved by / checked by / prepared by核准/审核/承办
    PCE assembly production schedule sheet
    PCE组装厂生产排配表
    model机锺
    work order工令
    revision版次
    remark备注
    production control confirmation生产确认
    checked by初审
    approved by核准
    department部门
    stock age analysis sheet 库存货龄分析表
    on-hand inventory现有库存
    available material良品可使用
    obsolete material良品已呆滞
    to be inspected or reworked 待验或重工
    total合计
    cause description原因说明
    part number/ P/N 料号
    type形态
    item/group/class类别
    quality品质
    prepared by制表
    notes说明
    year-end physical inventory difference analysis sheet 年终盘点差异分析表
    physical inventory盘点数量
    physical count quantity帐面数量
    difference quantity差异量
    cause analysis原因分析
    raw materials原料
    materials物料
    finished product成品
    semi-finished product半成品
    packing materials包材
    good product/accepted goods/ accepted parts/good parts良品
    defective product/non-good parts不良品
    disposed goods处理品
    warehouse/hub仓库
    on way location在途仓
    oversea location海外仓
    spare parts physical inventory list备品盘点清单
    spare molds location模具备品仓
    skid/pallet栈板
    tox machine自铆机
    wire EDM线割
    EDM放电机
    coil stock卷料
    sheet stock片料
    tolerance工差
    score=groove压线
    cam block滑块
    pilot导正筒
    trim剪外边
    pierce剪内边
    drag form压锻差
    pocket for the punch head挂钩槽
    slug hole废料孔
    feature die公母模
  • 石长老
    第1楼2007/01/07
    expansion dwg展开图
    radius半径
    shim(wedge)楔子
    torch-flame cut火焰切割
    set screw止付螺丝
    form block折刀
    stop pin定位销
    round pierce punch=die button圆冲子
    shape punch=die insert异形子
    stock locater block定位块
    under cut=scrap chopper清角
    active plate活动板
    baffle plate挡块
    cover plate盖板
    male die公模
    female die母模
    groove punch压线冲子
    air-cushion eject-rod气垫顶杆
    spring-box eject-plate弹簧箱顶板
    bushing block衬套
    insert 入块
    club car高尔夫球车
    capability能力
    parameter参数
    factor系数
    phosphate皮膜化成
    viscosity涂料粘度
    alkalidipping脱脂
    main manifold主集流脉
    bezel斜视规
    blanking穿落模
    dejecting顶固模
    demagnetization去磁;消磁
    high-speed transmission高速传递
    heat dissipation热传
    rack上料
    degrease脱脂
    rinse水洗
    alkaline etch龄咬
    desmut剥黑膜
    D.I. rinse纯水次
    Chromate铬酸处理
    Anodize阳性处理
    seal封孔
    revision版次
    part number/P/N料号
    good products良品
    scraped products报放心品
    defective products不良品
    finished products成品
    disposed products处理品
    barcode条码
    flow chart流程表单
    assembly组装
    stamping冲压
    molding成型
    spare parts=buffer备品
    coordinate座标
    dismantle the die折模
    auxiliary fuction辅助功能
    poly-line多义线
    heater band 加热片
    thermocouple热电偶
    sand blasting喷沙
    grit 砂砾
    derusting machine除锈机
    degate打浇口
    dryer烘干机
    induction感应
    induction light感应光
    response=reaction=interaction感应
    ram连杆
    edge finder巡边器
    concave凸
    convex凹
    short射料不足
    nick缺口
    speck瑕疵
    shine亮班
    splay 银纹
    gas mark焦痕
    delamination起鳞
    cold slug冷块
    blush 导色
    gouge沟槽;凿槽
    satin texture段面咬花
    witness line证示线
    patent专利
    grit沙砾
    granule=peuet=grain细粒
    grit maker抽粒机
    cushion缓冲
    magnalium镁铝合金
    magnesium镁金
    metal plate钣金
    lathe车
    mill锉
    plane刨
    grind磨
    drill铝
    boring镗
    blinster气泡
    fillet镶;嵌边
    through-hole form通孔形式
    voller pin formality滚针形式
    cam driver铡楔
    shank摸柄
    crank shaft曲柄轴
    augular offset角度偏差
    velocity速度
    production tempo生产进度现状
    torque扭矩
    spline=the multiple keys花键
    quenching淬火
    tempering回火
    annealing退火
    carbonization碳化
    alloy合金
    tungsten high speed steel钨高速的
    moly high speed steel钼高速的
    organic solvent有机溶剂
    bracket小磁导
    liaison联络单
    volatile挥发性
    resistance电阻
    ion离子
    titrator滴定仪
    beacon警示灯
    coolant冷却液
    crusher破碎机
