阳光模拟测试技术 标准
  • Amsler测试技术
    2019/12/11
实验室建设
  • 阳光模拟测试系统执行的标准包括:
    GR-487-CORE
    Electronic Equipment Cabinets
    AECTP 300 Method 305
    Solar Radiation
    AK LV 01
    Airbag Test
    ASTM E927
    Standard Specification for Solar Simulation for Terrestrial Photovoltaic Testing
    BMW PR 306.4
    Solar Simulation for equipment parts
    DBL 4571
    Interior Trim Parts
    DBL 5471
    Covering and Form Padding Parts
    DBL 7384
    "Soft Feeling" Paint on Plastic Parts - Interior Components
    Dessault Aviation
    Solar Simulation Test
    DIN EN 60068-2-5
    Electrical engineering - Basic environmental testing procedures - Part 2-5: Tests - Test Sa: Simulated solar radiation at ground level
    DIN EN 61646 VDE 0126-32
    Thin-film terrestrial photovoltaic (PV) modules - Design qualification and type approval
    DIN EN 61853-1
    Photovoltaic (PV) module performance testing and energy rating - Part 1: Irradiance and temperature performance measurements and power rating
    DIN IEC 68-2-9
    Electrical engineering - Basic environmental testing procedures - Part 2-9: Tests - Guidance for solar radiation testing
    DIN SPEC 18035-7
    Sports grounds - Part 7: Synthetic turf areas
    DVM 0006-EX
    Exterior Lighting-Sunload
    DVM 0074-MA
    Ageing of interior components by sunload simulation
    EN 12975-2
    Thermal Collector Testing
    EPA 40 CRF Part 86
    Control Air Pollution from New Motor Vehicles and New Motor Vehicles Engines
    Fiat 9.03141
    Instrument Panels
    GM 9310P
    Variabel Surface temperature heat exposure test
    GOST 20.57.406
    Testing of Electrical Components
    IEC 51345
    UV Test for photovoltaic Modules
    IEC 61215
    Crystalline silicon terrestrial photovoltaic (PV) modules - Design qualification and type approval
    IEC 904-9
    Photovoltaic devices - Part 9: Solar simulation performance requirements
    ISO 12097-2
    Road vehicles - Airbag components - Part 2: Testing of airbag modules
    JSS 5555-No.25
    Enviromental Test for Electronic and Electrical equipments
    LH 259001
    Electronical Equipments
    MIL-STD 810
  • qqqid
    第1楼2019/12/30
    全是英文的,国内没有相关标准吗?
  • qqqid
    第2楼2019/12/30
    配图前两张好象不是阳光测试。
