malibing
第1楼2020/04/23
比较粗略的话,可以直接计算获得,计算方法参考一下链接。需要精确的话建议做内标曲线。 Zhu, G., Zhao, F., Wang, D., & Xia, C. (2017). Extended effective carbon number concept in the quantitative analysis of multi-ethers using predicted response factors. Journal of Chromatography A, 1513, 194-200. https://www.sciencedirect.com/sc ... i/S0021967317310191 |
