求文献一篇
文献检索-互助
  • https://doi.org/10.1039/D0RE00252F
    From batch to continuous free-radical solution polymerization of acrylic acid using a stirred tank reactor?
    Juri Ilare,a Mattia Sponchioni, *a Giuseppe Stortia and Davide Moscatelli a
    Author affiliations
    Abstract
    Nowadays, the majority of the world polymer production is obtained through discontinuous or semi-continuous processes. In the specific case of free-radical polymerization (FRP), discontinuous processes suffer from many limitations with respect to safety, productivity, product quality and cost. In this work, we report a model-assisted strategy for transition of the solution FRP of non-ionized acrylic acid (AA) from batch to continuous with the aim of preserving the product quality in terms of weight-average molecular weight. A basic kinetic model is developed and validated by comparison with experimental results for three reactor configurations, batch, semibatch and continuous stirred tank reactor (CSTR). Then, examples of transitioning from a semibatch to a continuous process, using a stirred tank reactor, are analysed. Taking advantage of the validated model, a successful transition is designed through an optimization procedure. Based on a minimum acceptable monomer conversion of 98%, an increase in the polymer productivity up to 88% is achieved.
  • 砂锅粥
    第1楼2021/12/16
  • 该帖子已被版主-dong3626加5积分,加2经验;加分理由:参与应助
  • my321335
    第2楼2021/12/16
    这位大哥真厉害,谢谢了
